Results 1 to 10 of 17
Thread: Bars Leaks, been around since landys were invented.
    Just curious to know what the general opinion of the old bars leak product is? Why i ask is i've had a couple of 700km trips with the landy in the last fortnight and on returning from the first one i noticed the bloody P Gasket had a slight weep, not long since i replaced it Any how i had to pick up a caravan on second trip so i put in a tin of bars leak and took off, travelled about 350ks unladen picked up van (1.6 ton) and headed back home same distance, all went well, got home home no leaks did not get hot, which was my main concern as to wether this stuff interferes with the coolant in any way, the coolants gone all milky looking !! but shes running like a pearler
    They say on the tin add every 10,000KS So what do you reckon??.
    Cheers Sumo
    gumby190 Guest
    I had an old Kingswood that survived on this stuff & made weekly trips to Oberon for years, stuff never gave me any grief.
    Australia
    Yeah the old Bars works a treat on most small leaks.
    My preference has and always will be, to fix the problem properly. But this also depends on the plans and attitude you have for vehicle in the future. This stuff won't do any long term damage and the formula apparently has inhibitor in it.
    For me it would always be a temporary thing, but I had a 65 corona which had a myriad of leaks and continued for some years after with this stuff in it, never ran hot, just wore out by itself in the end.
    I wouldnt count on it to go bush,but probably fine if around town for a while.
    Melbourne, outer South East
    A mate used in in his 80 Series Cruiser and claimed it swelled and softened all his hoses and stuffed his water pump. Cost big $. Now I can't verify that but would like to know if it is possible the product can have that effect.
    Nundle
    We used a product called CarGo Sealup in Leon, (recommended by a radiator repair place). It's copper particles in suspension, and when used according to instructions is claimed to even seal cracked heads (within reason I'm sure) Not expensive either and is available in Repco.
    Reason we used it was we had a radiator leak and the engine would overheat. They're aren't many places that repair genuine, original radiators, so this product was tried and to date has been ultra successful. I would stress that you must follow the instructions implicitly, which involves flushing properly.
    Numpty
    REMLR No 143
    Caboolture.Qld
    Read 'Nautilus Ninety North' The book written by the Captain of the first US Navy Nuclear submarine, on their shake down cruise (which was ultra secret) they had a leak in their cooling system for their reactor which they could not find, They surfaced at night off a town in South America and a couple of sailors went ashore in civilian clothing and bought up the towns supply of Bars Stop Leak which they promptly tipped into their system....no more leak, Upon return to base a strip down of the system could not find any sign of a leak.......The 'Nautilus' then went on to go under the northpole icecap........so yeah I reckon it is good stuff. I use it.
    lokka Guest
    Quote Originally Posted by numpty View Post
    Yep im with you on this one numpty i have used this in plenty of different vehicles and have had huge wins with it tho you have to follow the instructions to the letter and its sealed up sliped liners in a rover also id say when ron P38a reads this he will also put his 2 bobs worth in as we have both discussed this stuff in the past on here
    South Yundreup,WA.
    It does work well and as intended, but if you happen to pull down a radiator after use it does leave some sludgy residue, which in the long term can cause problems. I have seen this first hand in an old HQ I had used it in.
    2011 Discovery 4 TDV6
    2009 DRZ400E Suzuki
    2003 WK Holden Statesman
    Departed
    98 Ducati 900SS Gone & Missed
    Facta Non Verba
    Kiwiland
    A mechanic I know swears by using ground pepper. But I've never tried it.
    He claims it flushes out very easily and completely, unlike the stop-leak products he's tried.
    St Helena,Melbourne
    4.28 MB
    My BIL has an 80 LC 4.5 on lpg that did a head gasket about 6 months ago, he used an egg white and pepper mix and its still going strong and using no coolant . He is a mechanic but building a new house and running a business that sees him drive all over vic/nsw/qld means he didnt have time to repair it properly.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
