I have a 16in davies craig mounted to the inside of my rad it sits off to the inlet side and works great i killed a set of the twin AU jobbies in the muddy water they wernt a sealed fan like the DC and only lasted a few swims![]()
Gday all,
Have just been working on a few things in the 110 engine bay (removing air con system mainly) and I was considering fitting the EL Falcon thermo fans I have that used to be in my Range Rover.
Now there are a couple differences I can see, the major one being the top hose on the radiator fouling the cowel on the thermo's a fair bit.
Now obviously I could just chop away at the plastic coweling and "make" it fit but I thought I would check here and see if anyone has any ideas or pics on what they have done to fit thermo fans in a V8 110.
Thanks for any input.![]()
Mick
1999 Land Rover 110 Defender TD5 Cab Chassis
1985 Land Rover 110 County 4.6 EFI V8
1993 Track Trailer camper
G'day,
the thermo fans were fitted in mine from the factory and sit neatly in front of the aircon condensor. Maybe pick up a pair from the wreckers?
Mick
Mick, love to know the answer as i'll be doing the same....
But i have a few Volvo ones i'm going to try on mine...
I dont know the answer, but this post does help my post count.....![]()
All done. Steve drop by the shed and have a squiz if you like.
EL Falcon fans slightly butchered.....fit just as well as they do on the rangie's.
Now just need to remake the wiring set up to suit the 110 and it's a goer.
Also removed the air con shizzbo from the engine bay in anticipation of converting to firewall vent flaps again. I cant wait!![]()
Mick
I have some flaps if your looking for some....converting to firewall vent flaps again
Disco 4 SDV6 Auto
Disco 4 SDV8 Dual Cab Project
Disco 2 M57 Extra Cab Project
Foton Tunland Cummins ISF
Disco 1 3 door 4.6 V8 Auto
RRC V8 Auto "Classic" Softdash
RRC 300 TDI Auto
Disco 1 TD5 Auto Buggy
Disco 1 300 Tdi Auto Ute
SAME Explorer 70HP 4x4 Tractor plus Nell Loader
Subaru GDA WRX
Triumph Bonneville SE
Yamaha TTR250
