Results 1 to 10 of 15
Thread: aligning clutch plate
    Foot of the Otways
    What is the best way to align the clutch plate ? I can get an input shaft by the end of next week but was hoping to do it monday . any other options ? Its the standard landy clutch on the back of my 2.25 petrol .
    Jul 2007
    Hobart Tasmania
    Smile hello
    Hello wanalandy i use a quarter inch extension bar and build up the exact diameter of the clutch and input bearing on extension bar using electrical tape.
    If u sight it from behind it works every time.
    I have been using this method for years.
    very bush mechanic method
    hope it helps
    olmate Guest
    Ive tried everything from broom handles to the handles of large screwdrivers... more jammy than anything else there. I now have an input shaft and thats the trick.
    If you dont mind mucking about a bit do as timaus13 suggests - it does work very well. Best to get a look at it and sight it up from behind as suggested.
    A careful inspection of your collection of sockets may reveal one the right size. If not, pick one undersize and build up with electrical or masking tape.
    If you have access to a lathe, turn one up out of just about anything - I used wood on the last one I did on my tractor. Needs to have one diameter a push fit in the spigot bush/bearing and the other to fit inside the splines in the plate, also a push fit, and enough extra to be able to pull it out after the pressure plate is tightened down.
    Brisbane, Inner East.
    JD, a clutch aligning tool was and still is a first year apprentice college job for fitter/machinists in Qld. Exactly as you describe, with a knurled hand grip. Dimensions were usually provided for a variety of popular vehicles, to be chosen by the apprentice. Still have mine, for 48/215-FJ Holden. A turning between centres exercise, time allowed 45 minutes. Material- black bar to be set in a four jaw chuck, centred each end and faced to length, then turned and knurled between centres.
    URSUSMAJOR
    Quote Originally Posted by Brian Hjelm View Post
    Rather more elaborate than my wooden one turned up out of a piece of scrap timber - but probably did it in ten minutes - and sorry, it was not knurled!
    Oct 2003
    Godwin Beach Qld
    G'day Folks
    I think that you will find that you can still buy a Universal Clutch Aligning Tool from such places as Supercheap/AutoPro, and REPCO, then just build up the shaft with masking tape to match the spiggot bush size, so you can centre the shaft and clutch alignment cone but an old Input Shaft is the way to go and all your landy owing mates will pay you lots of cans for your special aligning tool.
    Yinnar South, Vic
    Universal clutch aligner tools are useless, there is only 2 ways to align a clutch
    1. with an old input shaft/machined dummy
    2. use your peepers
    Foot of the Otways
    Thanks heaps guys . I have done it by eye for now .But if i get a little upset that it won't go in i'll try a sledge hammer
    Keilor East, Victoria
    Quote Originally Posted by wannalandy View Post
    had this exact same dilemma this weekend, i ended up using the handle form my engine stand, just the right diameter
    Need a second pair of hands and a trolley jack to get the engine in, should be in and fired up this week
    ended up spending the weekend putting all the floor and trans tunnel back in
    Steve
