Results 1 to 10 of 11
Thread: Solved - RAVE PDF to PDF
    Kyabram, VIC 3620
    Well I have finally found a simple/easy solution to 'printing' pdf pages from rave manuals to another PDF document.
    Well not printing - but saving individual / several pages in a PDF format
    A new product out called PDF complete - is not adobe - but it works in PDF format.
    PDF Complete > Home
    If you decide to buy it, if you put in that you were refered by HP - you get it at a discount !!!!!
    So select a page or a range of pages you want, go to print, select the PDF Complete printer driver - and it will produce another document in PDF format.
    Sorry if this is in the wrong place INC - wasnt sure if to put it into the IT or technical bit.
    If it is in the wrong place I am sure someone will move it for me.
    Excellent. Ladas. I shall have to try it out.
    I often need to print a page from RAVE to answer a question here or on the RRNET forum.
    Thanks.
    Ron
    There's a few shareware and freeware utilities that also do this. I use CutePDF - Create PDF for free, Free PDF Utilities, Save PDF Forms, Edit PDF easily.
    Adelaide Hills. South Australia
    There is also Foxit pdf Free.
    Foxit Software
    Warburton, Victoria
    You can export the PDF's from rave to normal unlocked PDF's.
    Tricky, but there is a post i did a while back on it
    The free PDF viewer that comes with Xubuntu allows printing of any page or pages to a PDF file.
    Edit: ...or a hard copy.
    More edit: ... and that is probably true of most or all Linux Distros.
    Melrose SA
    PrimoPDF is one of the best
    Kiwiland
    Quote Originally Posted by djam1 View Post
    I switched from primopdf to cutepdf. The main reasons were cutepdf allowed me to use landscape with portrait and even mix in different size pages into the same file.
    Bayswater North, Vic, 3153
    X 2 ..... excellent
    tpb Guest
    Quote Originally Posted by sclarke View Post
    Sorry to resurrect an old thread...
    I'm attempting to do exactly what you describe, and I'm running into no end of problems. Where is your original post on the topic?
