Results 1 to 10 of 23
Thread: D2 99 hooks jointed drive shaft?
    Nov 2007
    Question D2 99 hooks jointed drive shaft?
    "Also posted in Discovery forum"
    I have been told that my 99 TD5 should have a hooks jointed front shaft rather than the 2 standard Universals. Is this right or just another of those later model upgrades?
    The literature I see is yes just want clarify.....
    Cheers........
    Paul
    New :- D3 TDV6 2006 SE
    Bullbar, traxide dual battery
    General grabber ATs
    Mitch hitch
    Home made drawer and fridge system
    Foldable UHF antenna on roof rail
    Denmark WA
    Thumbs up Also called a Double Cardan Joint
    Yep it should have.
    Good idea to fit some greaseable unis in it too, and check the operation of the splines.
    Run a search on "greaseable uni joints" or similar. Or greasable? How dya spell it??
    1974 Military Lightweight Landy --- Some dementia at 50 years old
    2000 Disco series 2 now sadly moved on!
    No5 Trailer joined the fold... Awaiting graduation to road licensed!
    2021 Mazda BT50 or is that DMax?
    Nov 2007
    Hmmm Thanks Dave... thats what I was hoping for sort of....
    OK next question????
    Are the UJ plates different, they look to have different bolt centres so that you can only fit the hooks end to the transfer case.
    My D2 has the same setup at both ends which is why I asked about the later model upgrade.
    Paul
    General grabber ATs
    Mitch hitch
    Williams West Aust
    Sounds like an earlier D1 shaft has been fitted.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Nov 2007
    Thats what I was informally told LandyAndy.... but it doesn't seem to be JUST a D1 shaft as the bolt plate on the transfer case seems to have a different bolt centre setup so a direct swap doesn't seem quite feasible???
    Is this right?
    Paul
    General grabber ATs
    Mitch hitch
    Williams West Aust
    I think you will find they are all the same.
    D1/Rangie/Defender owners use the D2 shaft when they get tailshaft problems due to raised suspension kits causing binding of the uni-joints.
    Have a look at your rear tailshaft.A common D2 conversion is to replace the rubber donut at the diff end with an early standard tailshaft.
    May give further clues to how much messing a previous owner has done.
    Andrew
    Nov 2007
    Founf a thread Disco 1 Driveline Vibration in which Slunnie mentions a DC (Double Cardan) flange....
    I'm cringing at thought that I have a D2 with a D1 flange and shaft..... Anyone know where I can get a DC flange??????
    Paul
    General grabber ATs
    Mitch hitch
    Nov 2007
    Thanks for the clues Landy
    Rear end looks normal with robber donut... just hoping that a previous owner did a shaft and opted for a cheaper fix of a conversion to a D1 setup...Time to set it right me thinks.....
    General grabber ATs
    Mitch hitch
    Quote Originally Posted by pohm66 View Post
    To be pedantic.......
    The correct name for a conventional single universal joint is (in Britain) a Hookes Joint or, in Europe, a Cardan Joint.
    late edit: See Universal joint - Wikipedia, the free encyclopedia
    Williams West Aust
    Onya Ron
    RAVE CD actually calls it a hookes joint,I was only looking the other day.
    Paul,Im guessing on normal everyday roads the D1 would be fine.With big artic you could be in strife.
    Bundalene on Ebay had one with new greasable unis,earlier in the week.unsure if it sold.Try contacting him via his Ebay store.
    Andrew
