Results 1 to 9 of 9
Thread: Weber carburettor qualms!
    Hunters Hill, Sydney
    g'day all
    i've got a few issues surrounding my weber carbie on my 2.25 petrol. ok 1stly.
    To me it seems it drinks a lot of fuel (the fuel guage is dicky, but i'm still not getting very good mileage). I know they aren't the most efficient or aerodynamic of beasts, but i think this is a bit much. I know they are sluggish also, but i think mine might be a little overly so. When the engine is almost warm and i put the choke back in, i find it chokes a little or splutters in low revs, is this normal?
    1. I'm not exactly sure if its the carbie or not, but when cold there seems to be a lot of black, unburnt fuel coming out of the exhaust until the engine reaches operating temperature. I've fiddled with the idle mixture setting a tad, making it leaner and so on, but still there is unburnt fuel. I know someone who had as 11a, who said he also had the problem of stinking up the neighbourhood and using a lot of fuel (think he had a solex), but he changed the jet in teh carbie to a 0.25mm or something or other, and bingo, now it runs like a gem, he reckons he can spin the wheels in 1st and 2nd! I dont know if i beleive him, but i do know his has only got 33k original miles on it.
    I also have genie extractors on the car ( which i didnt recognise for ages!) which if anything, i think would help effeciency!
    So if anyone has any ideas, or theories, i'd love to hear them. I've also heard conflicting evidence regarding weber carbies in that, some sources say they are more effecient when driving at lower throttle movements as they are a 2 barrel carburettor (i drive as conservatively as i can). And thus this makes the weber less responsive (less performance). While other sources say weber's do enhance performance but inhibit economy. I've heard solex's can get better mileage?
    either way, i know there were some fuel probs with the car with the prev owner, which is why he fitted an electronic fuel pump and the weber carbie.
    sorry it's an essay!
    cheers!
    john
    I have no experience of the Weber, but any of the OE carburetters perform well when in good condition and properly adjusted. Certainly it should not be producing black smoke. It is possible, if it has a non standard fuel pump, that the fuel pump is producing a higher pressure than the carburetter is designed for, but I would not expect that the problem is in the carburetter itself, although this may be compounded by incorrect timing or other problems. For example, there may be a manifold air leak which has been compensated for (at some speeds) by larger jets.
    thanks john, your the man.
    just out of curiosity, what mileage do you get in your 2.25 petrol, L/100km?
    i will look into it.
    Quote Originally Posted by Bisho View Post
    I'm afraid I really don't know - it is used almost entirely around the farm, and I don't keep detailed fuel records. It would be around 20l/100km, but you have to realise that little of this is in top gear, and quite a lot in four wheel drive, and none on sealed surfaces.
    Jun 2007
    I have a friend who had one on his car he said he changed the main jet because the carbie was for a 6cyl
    thats very interesting lro11. i have always thought this was the weber designed for the 4 cylinder petrol, but i may be wrong. do you have any idea what size jet he changed to?
    cheers mate!
    Jun 2007
    No idea sorry my land rover manual says the petrol consuption should be 680ltr/5000km
    cool man. ( u should get him on the forum!! wink wink nudge nudge). So i assume thats for the standard carbie (zenith or solex...etc) is that for highway or city driving?
    Williams West Aust
    To check for manifold leaks get a can of CRC and fit the tube that comes with it.
    With the engine runing spray all the joints between the inlet manifold and head and between the manifold and carb.
    If there is a leak a change in engine revs will be evident when the spray is applied.
    Goodluck
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
