Results 1 to 10 of 15
Thread: half shafts check this out
    Jan 2008
    Ireland
    Nanny state UK...
    Pssst... they call them 'Axles' in Oz.
    M
    Jan 2008
    Ireland
    up here on top the complete assembly is called an axle . the test rig is for 'alf shafts as the tans callem . Anyone looking for info on trannies as you call them should view their site
    Christchurch NZ
    Quote Originally Posted by camel_landy View Post
    M
    And in New Zealand we call them half shafts too, calling them an axle is so american! Like calling a diff housing a pumpkin or a diff head a third member, where did the other members go?
    1995 Defender 110 300TDI :D
    1954 86" Series 1 Automatic :eek:
    Ex '66 109" flat deck, '82 109" 3 door, '89 110 CSW V8, '74 Range Rover, '66 88" soft top, '78 88" soft top, '95 Disco ES V8, '88 Surf, '90 Surf, '84 V8 Surf, '91 Vitara.
    Bracken Ridge, Qld
    Quote Originally Posted by stock View Post
    Here we just call those f****n pooftas !
    gone
    1993 Defender 110 ute "Doris"
    1996 Discovery 1
    current
    NSW far north coast
    Quote Originally Posted by jimbo110 View Post
    or Ring and Pinion for Crown Wheel and Pinion. I will call it nothing but a CWP !
    axle/half shaft is pretty much interchangeable here., although the term half shaft is usually applied more to independent diff/axle assemblies with exposed shafts.
    and fancy a Kiwi counselling us on language !
    at least we can count to ten without mentioning procreation half way through ....
    Oct 2006
    canberra
    and at the end of the day what was the point?
    May 2003
    On The Road
    interesting it broke the shaft,,
    would have bet money on the cage,,
    3M swayaway's will do 360 deg and return,,
    dont know how many Nm's that is but,,,
    NSW far north coast
    now that I've actually seen the vid and by who, Dave visits and posts in here sometimes, and was only here in the last week or so.
    <edit> and It'd be much more interesting if it showed the force at breakage vs the force at breakage of their new CV's.,
    Jan 2008
    Ireland
