Not sure who to go to over there in NZ but VDO and Stewart Warner both make excellent gauges that can deal with 24v at a reasonible price. As for how to connect them most good auto electricians can help you with that. But if you want to do it yourself, are you running electronic ignition? It should have a tacho output if not and you still have a coil then you can get a pulse off the negative side of it. Then all you need is ignition +24v and a good earth.
I hope this helps,
