does it do it only from cold?
does it do it more or less when your over running (engine braking) the engine?
how is your crank case ventilation setup on that engine?
hows it go under load?(and does the smoke get worse?)
Which air filter have you got? (oil bath or paper element?)
to work out which cylinder is doing it get it started and as soon as it starts puffing the wierdo smoke crack off the injecter unions one at a time (tighten them up after each one and cover with a rag to prevent fuel spray
if you can answer those questions then we're on the way to an answer.
it could be a handful of things starting with a compression ring not sealing and vaproising enough oil to be drawn into the combustion process via the crankcase ventilation to cause the smoke, to an oil ring sticking and not scraping the bore enough with the resultant oil causing the smoke.
if youve got an oil bath air filter you might be drawing something up out of that (and thats on the way to a runaway)
If it is burning oil in any of those ways you need to investigate it and recitfy imediately, while the 2.25 struggles to turn over on one pot when its cold if you get 2 or more going they can run away when hot... doesnt happen often as you can usually just dump the clutch in 4th with the brakes up hard to stop them but imagine if youd just walked away from it for a couple of minutes and it all turnes to pears.
