Results 1 to 4 of 4
Thread: Coming to Australia - Bluey's rebuild part 5a
    Dubbo,NSW
    Hi everyone,
    here's the photos I promised of Bluey.
    I have got the engine running properly - I hadn't tightened up the tank to lift pump fuel line at the pump end so it was obviously sucking air. I've also replaced the viscous coupling so the fan should be sorted.
    I'm currently rebuilding the seat box with new sides, genuine tool box and a replacement battery box with a flat floor so fitting twin batteries should not be a problem. I thought it would be a quick job but seven hours later and its still not finished!
    Anyway heres the photos.
    Andy, Rosy and Abby
    SIII 88" Petrol 1978
    SIII 88" Diesel 1977
    90 2.5 Diesel 1986
    GS 101" Modified 1979
    Range Rover Vogue SE 1990
    I now drive!? 1994 200Tdi 110
    80" 1950
    Cessnock NSW
    G'day All,
    It's starting to look good, just out of curiousity what is behind the T/case?? cheers Dennis
    PS What is the timetable for your arrival down under?
    Dubbo,NSW
    Hi there,
    the mystery object behind the transfer case is a disc hand brake in place of the drum. Its sold by X-Eng and is a quality bit of kit and was very easy to fit. With Bluey spending most of the rest of his life heavily laden I wanted a decent handbrake. The caliper is normally used on heavy plant machinery so Bluey shouldn't present much of a problem for it.
    The timetable for our departure for Oz is pretty much dictated by our 3 month old daughter Abby. We have to wait until she's old enough to travel ie she's had all of her immunisation shots. We are hoping that it will be in about 18 months time.
    Andy,Rosy and Abby
    90 2.5 Diesel 1986
    80" 1950
    Nundle
    It's looking good Andy. Seems like you'll be doing a fair bit of socialising with AULRO members when you finally get here.
    Numpty
    REMLR No 143
