PhilipA has a great write up about fitting O2 sensors to the 3.9 V8. Was for a Rangie Classic so the computer etc is in a different spot but the rest should be the same.
It's in this forum somewhere.
You do have to drill holes in the exhaust and weld nuts on as there is no unused mounting spot for them.
) and I wondered if any of you have overcome this hurdle before?
Except that this time, the block will have cylinder liners that are "top hatted", i.e. they will not slip down the bores.
