Results 1 to 9 of 9
Thread: Disco towing
    Kev Guest
    Disco towing
    I regret that I am new to this great forum and the topic may have been covered many times before.
    I have a 1990 Disco and I use it to tow my trailer sailer (all up weight is 1850). I used to use my Series 3 but that will be leaving home soon.
    Both the truck and trailer are level when loaded.
    I do take the outboard motor off the boat and place it in the nose (bow) of the boat for long distance travel because I am told the towball weight is light. Towing around the island I leave the motor mounted and travel slow.
    The trailer seems to push me around particularly on rough roads. I am not very experienced at towing and am not interested in travelling at high speed with my pride and joy behind me.
    It has been suggested that I should change the oil shocks to Bilsens and insert air bags in the coil springs. Rather than reinvent the wheel could people that have been down this path give me informed advise please.
    I fear that my not knowing what I am talking about is an opportunity for a salesman to rip me off. The article on Caravan towing was very interesting. Thanks Ron Mc. Sorry if this thread bores the veterans.
    Williams West Aust
    The airbag inserts are a must for towing,they stiffen the rear end no end.I regularly tow 2tonnes plus,rides perfect.
    Well worth the money for a set.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    the bilstiens are a good shock but if what you have is working leave them till they stop and then fit the bilstiens. The airbags are good for helping the springs if your running heavy on the tail end from internal load or you want to fit a lighter duty spring and have the ability to go back to a heavier load.
    1.8t isnt much shy of the weight of a clean disco anyway so its going to push you around a fair bit as is.
    Dalby
    If the truck is level when loaded then the polyairs won't do anything for you.
    Does the trailer push you around all the time or just when the motor is on the back?
    With the trailer off the car can you lift the front of the trailer by hand?
    If the towball download weight is between 5-10% then you shouldn't be able to as even 5% is 92.5kg (Disco1 is max 150kg towball download by the way).
    My guess is either the towball weight is too light or the trailer brakes aren't working properly.
    99.87 MB
    Here is what I find... and it may go against the grain a bit.
    Tandem trailers... I would assume its a tandem axled trailer and I belive these do cause the car to move around a fair bit in the rear, especially when loaded. I notice this when driving straight ahead, or after I've just turned into a corner. These trailers, especially when there is some load in them will always want to track straight ahead, and tries to always push the rear of the car in the direction that it wants to go. I notice it when driving straight ahead on the highway as the tow vehicle ever so slightly meanders, the trailer will accentuate this feeling as it tracks straight. Also when you turn into a corner, the trailer will push the rear of the vehicle straight for a touch until the trailer also turns into the corner.
    The other thing that exacerbates the same feeling I think is running to heavy a ball weight. When you have too much load at the front of the trailer it will cause exactly the same problem as above due to the inertia that is required to make the heavy load change in direction. Unless there is a specific reason to have a heavy ball weight (such as a car needs to be in a certain spot on a float) then I don't. I don't measure ball weight by the kg either, it's unrealistic when loading the trailer, I measure it by the drop in suspension. Running 300-340 rear springs I can workout roughly what the ball weight is by the drop in suspension ride height, and from my experiences the best handling setup is when the ball weight is not heavy. I wouldn't ever try to run 250kg ball weights, even with a caravan as I think it will handle like a pig and wreck the car. If you keep the loads heavy centralised it wont wag the trailer. ie, try putting the motor into the boat, but over the trailer axles.
    I think a lot of this feeling of the car moving around is actully due to the flex that is generated in the tyre sidewalls allowing it to move around. To help here, whenever towing a tandem axled trailer I increase the 4WD's rera tyre pressures to about 45-50psi which reduces the movement. If your ball weight isn't heavy, which is what it sounds, then don't worry about polyairs.
    Slunnie
    Kev Guest
    I appreciate your ideas on Disco Towing
    The side wall idea makes sense as I just upgraded the types to the largest footprint I could get for the rims. I thought a larger footprint would be safer.
    The air bags sound like a tried and true idea as are replacing the original shocks with Bilsens.
    The weight away from the back of the boat makes sense and the physics of a trailer tracking because it is a tandem rings a bell.
    I will take on all your ideas as I feel they are all valid.
    Increase air pressure, move the weight are easily done and it looks like I will change the rest of the ideas as well.
    Thanks for your ideas folks.
    Kev
    with a tandem trailer beefing up the cars rear tyres helps as does bagging the trailer tyres down a little.
    RonMcGr Guest
    Hi Kev,
    Sounds like your tow ball weight it a little too light.
    If it is possible, move the craft forward on the trailer.
    If all that doesn't help, try one of these:
    Caravans Plus - DIY Parts & Accessories
    Manly QLD
    Right up my alley
    Hi Kev – I’ve spent a lot of time dragging heavy boats along the east coast – the heaviest (Haines Signature 850 at 4.4t) was not towed with a rover but the trailer was set up exactly the same as what I describe below.
    The biggest problem with some rigs is that they are balanced (no ball weight) imagine a balanced see saw it can easily swing up and down and on poor road surfaces will want to swing side to side. 1850kg is the same (very close) as the empty weight of the D1 so the car has no weight advantage. Add to this the point that Trailer Sailers sit on trailers with the axle assembly under the middle of the rig so you also loose the advantage of a long drawbar – like would be found with a powerboat. By your comment that the vehicle sits level I’d say Your problem is because the boat & trailer are getting a mechanical (leverage) advantage over the car. This is compounded by the short wheel base and relatively big rear overhang (compared to wheel base) on the disco.
    What I found -- by moving the axle assembly back (it won’t be much) you increase the drawbar length (lever that the car has to control the rig) and decrease the rear over hang (uncontrolled lever weight). You also add weight to the car tow ball – this is (in my experience) misunderstood. Bringing the ball weight up to (D1 max) of 150kg means that the see-saw no longer has the tendency to rock and swing, one end is now 150kg heavier, and the car tyres now have hold of that 10%. The down side is the you have ‘lifted’ weight of the front (car) wheels – this is the problem with high ball weight, It’s not just a case of the car and trailer not sitting ‘level’ - that’s a symptom. As Ron has detailed in the caravan thread a Load distribution Hitch will do exactly that – transfer weight back to the car’s front wheels (car will sit level again) You need to get weight on the front wheels again to maintain steering geometry and prevent braking lock up (no ABS I assume)
    Tyre pressure should be lifted on the car and if the trailer tyres are anything other than rock hard the tyre walls will allow sway – I could always tell if the trailer tyres were less that 55psi. (will depend on tyre type and weight/tyre - tandem might not be load sharing)
    When I purchased one of my boats (gvm 2.8t) it was set up with less than 20kg on the ball and at speeds over 80k was downright dangerous, would get side to side swaying up big time. We moved the axel assembly back (only about 6 inches) resulting in just under 250kg on the ball (add Reece WDH) – completely transformed the setup – very stable at 100 -110k and high side winds behind the D2.
    Another issue could be the trailer itself – some of the lighter trailers flex a lot! As you can see in the drawbar pics I doubled it up – I did this with every boat trailer I’ve owned and set up for others, with his one I ran the 2nd draw bar back down the middle to just before the front axle assembly cross member. Two extra cross members were also added between the A frame and axle assembly to prevent the chassis from spreading as the whole thing flexes (and they do – a lot!) Total extra weight 34kg.
    Depending how keen you want to get ---- I also added shocks to all wheels, once 2.5 to 4.5t of trailer starts to ‘bounce’ at speed you are in for an exciting ride even with a F250.
    I set these (6 in all) rigs up to tow safely, stress free and fast. I (and friends that I set up rigs for) wanted to leave home and travel at 100-110 to our destination without having to worry about chewed out foundations on our ‘great’ highways – there was a heap of work went in to them but the result was astonishing. One of my creations (for my retired father) carries a 2.6t plate alloy cruiser and he tows with a (320,000km) disco 1 – he’s on his 2nd set of shocks....
    Off the track – As a sailor you may pleased to hear that my powerboats are gone – replaced by my first set of sails
    Pics 1,2 Drawbar with LDH - pls ignore the toyota...
    3 the shock mount inside the chassis rail.
