Results 1 to 10 of 12
Thread: Standard Spare Wheel carrier coming apart
    DiscoDave Guest
    The latest niggle on my Disco, which is having a bad month so-far, is the studs on the spare wheel carrier on the rear door, are pulling out. The lower one broke free a few weeks ago and now a second one seems to be pulling loose. I'm only putting the spare on with the standard wheelbrace, not using a rattle gun or anything...
    So weld them in place? Or just get a replacement carrier?
    Anyone else had this problem?
    weld them but dismount the whole carrier first and weld them from both sides.
    May 2003
    On The Road
    yea, long time ago,,
    after the simpson,,
    take it easy on the welds where the wheel bolts on
    (as opposed the door side)
    doesnt take much to stop the wheel from sitting flush.
    If worst comes to worst and you can't fix it by welding, they aren't a terribly expensive an item.
    Mar 2007
    South Arm, Tasmania
    I broke one recently and was told that you couldn't buy the studs separately. Apparently they are different to those in the wheels ??????
    Can't remember what I was quoted for a complete carrier - all I did was went to the local bolt shop and got a bolt with correct thread, cut length down to what was required (the nearest I could get was slightly too long) and welded bolt in from the back of the carrier. Haven't had any problems with this since.
    Cheers .........
    BMKAL
    St Helena,Melbourne
    4.28 MB
    Seems to be a common occurance, my bottom stud was missing and a bolt in its place. I bought another carrier that i will weld the studs both sides before re fitting and using the spare one for my camper trailer.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Adelaide - Torrens Park
    I think the part number of the carrier changed about 12 months ago. THe new one is made of thicker metal to help prevent cracking issues. It might be worth getting one of the new ones.
    DiscoDave Guest
    Thanks for the helpful replies everyone. Lots of good ideas there!
    Warburton, Victoria
    Bonnet mount it.... now there is an idea.....
    Then you will be one step closer to the Superior 4WD
    Williams West Aust
    Any idea if this is a D1 only problem???
    I only ask as Im about to fit 2 D2 wheel carriers to the off-road trailer Im building.I went and looked,the stud mounts seem OK.If it effects D2,its easy enough for me to re-inforce the carriers whilst Im building the trailer.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
