Results 1 to 4 of 4
Thread: Which Cargo Barrier
    Mar 2007
    Mitcham, Vic
    Which Cargo Barrier
    I'm looking at putting a cargo barrier in our DII preparing for a trip mid year. Being a 7 seater that do occasionally get used, the cargo barrier needs to be easy to remove and reinstall.
    Having been given the sales pitch for both the brands, I would appreciate some opinions from others including:-
    • easy of use
    • ease to install initially
    • advantages of one brand over the other
    • does it need to be rated (one brand isn't for the DII)
    Thanks in advance for your opinions.
    Derek
    There's more than one brand?
    Mar 2007
    Mitcham, Vic
    two to chose
    Milford, the expensive one
    Autosafe (Tradesman Engineering) often used by the cargo system companies.
    Derek
    Invermay Tasmania
    Try 4wd systems in SA 08 8369 0033I found them the cheapest but you do have to install it yourself.
    All barriers should be easy to remove.
    The one I have in my ford wgn in held in by 4 screws and only takes about 60 sec to remove
    Adam
