Thread: 3.9 Isuzu Engine Mounts
    Oct 2007
    JUST NORTH OF COFFS HARBOUR NSW
    Hi all i'm after a pair of engine mounts to suit a 3.9 isuzu,the cheapest ones i have found is $210 a pair.If any one can get them cheaper i would love to know.
    CHEERS TIM....
    These prices may or may not be still current.
    5532150310 RH mount $71
    5532150321 LH mount $78
    from my local LR specialist.
    Where are you located - update your profile, it really does help us help you.
    Piggabeen (Tweed Heads)
    Engine mounts
    I just got the last set in stock at LR Sydney $170.00 the pair. The bags do have an Isuzu part number so could possibly get them from Isuzu?????
    If you need the numbers I,ll dig the bags out.
    Justin
    you can get them from isuzu or LR the isuzu ones are different to the LR ones but not significantly.
    If you can grab the rubber protective boot that goes over the right hand one and put it on the left one as well.
    Darwin
    Have you figured out why they only list those boot covers for only one mount?
    I have put one on each side but it eludes me as to why they only put one on one side with the county.
    they only put one on the right side, near as i can figure its because it sits pretty much under the bleed points and the primary fuel filter and dieso and rubber do not make good bedfellows.
    Oct 2007
    Thanks for the help guys,i purchused some today.
    CHEERS
    REGARDS
    TIM....
