1. Conversion to diesel - replace engine with 2.25 diesel. Everything bolts up, add fuel return line, throttle linkage a bit different, wiring a bit different, new front exhaust pipe, that is about it. Oh, you should fit heavier front springs as the diesel is heavier.
2. Conversion to Stage 1 - nowhere near as easy. The front axle is unique, the chassis and steering arrangement different, engine and gearbox mounts different. It can be done, but the Stage 1 axles (rear 3.54 diff, front just about everything different for full time four wheel drive) are found in the same place you find hen's teeth. It could be done - BUT! To do it would need dedication, money and perseverance.
An alternative, would be to fit another diesel - more work than the Landrover diesel, but less than trying to do a stage 1 conversion.
