Your hand book should have a section on recommended lubricants.
I am assuming it is a TD5.
Oil every 5000kms I do mine.
Oil and filters (inc air) every 10,000kms I do mine.
Fuel filter every 40,000kms ( I do mine every 20,000kms).
I also do my gearbox, tranny and diffs every 20,000kms or more often if water crossings involved or possible contamination.
Brake and clutch fluid every 12 months.
Manual gives longer service intervals but is cheap insurance.
Coolant will need to be OAT - Nulon red is widely available and should be diluted 30-50% with demin water.
Oil I use Penrite, but any good synthetic or semi synthetic will do 5W.
Penrite MT oil or ATF fluid (have used Valvaoline and Castrol).
Redline fluids are good but expensive.
Castrol brake fluid is ok, but remember it is hydrophobic, so once opened it should be used reasonably quickly. If I am flushing the system, I first flush with open new fluid and then open a new one and flush again. Flushes out any crap.
