Results 1 to 3 of 3
Thread: body lift
    wells Guest
    body lift
    hi all , i have heard of some guys making there own 2 inch lift kits out of 2 inch round au bar ,is this ok to do and if so how hard is it to fit them , do you just undo all the standard ones and replace the bolts etc ???
    wells Guest
    Oh Sorry Its A 89 Rrc ,and Will It Need To Be Round Bar ? And Do I Leave The Rubbers In Or Take Them Out ?
    Rangier Rover Guest
    Quote Originally Posted by wells View Post
    Leave em in. Body lift is involved as Brake pipes, Steering shaft, Radiator cowl, Seat belt extensions,Frount and Rear bar, Brackets, Fuel filler, front and raer bar just to name some all will need mods. Best talk to an engineer first if making your own so its safe and leagle. Sounds bad but they are easy to to. Once done they are better to work on. 2.5" is most popular. Can run 35's with a guard trim and flares on standard suspension is posible.
    Cheers RR
