Thread: Anybody got those parts...?
    Samford, Qld
    Hi all,
    I am still after 1 d/s lower door hinge S2 or 2a and lately those little 2 lower brackets that screw to the radiator surround to hold the grill in place, see picture. Can anybody help...PLEASE
    Thomas
    Foot of the Otways
    Howdy mate i have a series 2a door hinge you can have just pm me with what you want to do
    I should have the brackets somewhere - PM me if you don't get any locally, although they are not much to post.
    Jun 2007
    Wow Thomas looking good can't wait to see it finished
    Cessnock NSW
    G'day All, I have all those parts and some! if you need them, smart looking LHD Land Rover you have there cheers Dennis
    PS I hope you replaced the 4 x 3/16" blind rivets at the front section of both guards as they tend to suffer badly from electrolysis and do let go and thats a shame after you have the top coat of paint on, anyway cheers.
    Samford, Qld
    Hi all...
    APOLOGIES, the LR in the picture is not mine, it is the one on www.roverhaul.com , I think somewhere in Canada, just put it up to show the "brackets". I am going for the same colour though but definitely not that level of perfection. I am happy if it is 60% of that.
    It seems like I am getting the hinge from Wannalandy/Mick, thanks for that. After getting a couple from lro11 (thanks Darren) I decided to change all hinges to Series 2 as they can be overhauled. My Series 3 hinges are just too loose. Purists, pls forgive me.
    I am still looking for those brackets, I will PM you guys.
    Again, (unfortunately) not my LR, sorry to disappoint...
    Thomas
    Cessnock NSW
    G'day All, Mate you cannot use Series 2/2A hinges on a Series 3. The hinge mounting point is different, the Series 2/2A had a sliding plate behind the 'A' pillar, the Series 3 had "speed nuts" for the want of a better description, and part of them stand proud of the 'A' pillar, the back of the Series 3 hinge is hollow to accept this, the Series 2/2A are flat and will not sit square if you follow what I mean, hope that is of some help cheers Dennis
    Samford, Qld
    Hi Dinty,
    I think I know what you mean, thanks for that, I will take a look tomorrow, I may have to fabricate something.
    Thomas
    Cessnock NSW
    G'day All, Mate I will knock off the rivets holding those 2 lugs for you tomorrow and hopefully post them to you on Monday cheers mate Dennis
    PS You could repair the Series 3 door hinge by knocking out the pin and making the hole oversize and then fit a Selloc roll pin, I'm certain it would fix the problem, anyone else got any ideas??.
    Samford, Qld
    Hi Dinty,
    thanks again. I had a look at it just now and you are absolutely correct.
    There is a simple workaround though by just copying the 2a design. I made up a sliding plate like you suggested and I can slip it through the opening where the "speed nuts" go. I used a thick plate and tapped a thread into it. It's a little fiddly to put in but seems to do the trick.
    Thank god you mentioned that now so I can prepare those parts!
    Let me know what you want for those brackets.
    Thomas
