Results 1 to 3 of 3
Thread: 110 Leaky Windscreen
    Capt Exxon Guest
    I have a 06 110 Wagon that has just started leaking through the compressed foam seal just below the windscreen. Obviosly the vehicle is still under warranty and was aware this may happen.
    Any suggestions on a real fix not a bandaid.
    Sarg
    Jan 2008
    Gladstone, Queensland
    Check the bolts on the inside behind what used to be hinges from when you could fold the windscreen down. Mine were loose on about a year after I bought it. Failing that take it back to the stealer and ask him to fix it. Don't be surprised if after several visits it's still the same. They pretty much all leak and some have joked that it's a factory fitted option.
    Anyway, good luck with the stealer. You'll need it!
    This also turned out to be the leak with mine. Took a long time to track down, and to fix needed their removing and refitting with sealant on each side of the gasket.
