Results 1 to 10 of 13
Thread: 101 Recovery Points
    101 Recovery Points
    101s have aluminium helecopter lifting brackets front and rear. Clearly designed to lift the 101 vertically in its lightweight condition - so say 2.5 tonnes spread over 4 points.
    I have noticed a lot of pics of 101s with recovery shackles etc attached to these points - now these points are designed to lift vertically not pull and and such I would not have thought these to be good recovery points - particularly for snatches.
    Like snatching from towballs - I would have thought that snatching from the pintle hook would be unwise - even if they were strong enough I suppose there would always be a chance the strap could pull through the hook and catch (whatever the top bit is called)
    What have other people done for recovery points in their 101s. Just used the helo lifting points or pintle hook or put something special in.
    Jan 2008
    Nowra NSW
    The front helicopter lifting points are most likely missing on your vehicle.
    They are like the front and rear points but located on the cabin on the floor either side.
    In its light weight condtion two lifting straps went to the rear chassis points with the tail gate removed.(straps bent over rear body a bit)
    On the front the straps went straight to the floor lifting points.......as the canvas roof has been removed.
    The front chassis points are not helicopter.
    JUst checked in the book.........the front chassis points are discribed as towing and lashing points.
    I have been recovering vehicles in the army and privately for years.
    Recovery on a pintel hook is no problem so long it is closed and the safety pin fitted.
    The original chassis points are fine for light recoverys.
    It is up the person to in charge of the recovery to decide the best attachment point to a vehicle for the situation.
    If you dont like a pintel hook put the strap around the diff.
    Even better use the101s excellant recovery winch for recovery,instead of the uncontrolled forces of a snatch recovery.
    If I was using the rear or front points I would share the load between them with a bridal and not for snatch.......but winching would be OK.
    Central Queensland
    what abous using the steel eyes designed not to slip out of a closed and locked pintle hook instead of just using the strap on the hook
    Jan 2008
    Nowra NSW
    I think you will find the towing points are cast steel and not alloy.
    Mine are steel.
    Ron,
    You are of course correct - the attachments on the front bumber are for towing/tiedown and not for helo lifting - as they are the same as the rears I assumed they were for the same purpose. Mine appear to be aluminium but I just tested them with magnet and they are ferrous.
    I am sure they are plenty strong for recovery and snatching - I just have an aversion to having recovery points where the strain is taken by the bolt threads rather shear force on the bolt shaft.
    I appreciate there are other options but was just curious what other people have been using.
    Thought I'd give this a bump. I'm tentatively booked in on the 10th Jan for my first off road outing and want to know what others have used for recovering their 101 or pulling others out.
    I don't have the luxury of a winch so cant choose that option. A lot of the 4wding I do is sand based and while I've never been bogged yet on in the sand (touch wood), I want to be able to be recovered or recover others if required and its likely a snatch would be on the cards.
    I'm keen for what others have actually used. If you've had after market points put on I'd like to know as well.
    Cheers.
    Dec 2009
    Williamstown, Barossa, SA
    Hi Stuee.
    On the rear, Im of the opinion that the NATO hitch when mounted directly to the center of the xmember with all original points is a good recovery point for the rear, as the xmember is a decent size, and also has 45deg stays back to the chassis rails. I have carried out a few light snatches and a few heavy snatches with my UK 101 with no issue.
    The front is a different story, and offers little in the way of recovery points. The 'air portable' eyes are not sufficient (same with rears), which is why they are on the shelf in the workshop. I've addressed the front recovery point on mine by building a jaw into the new bumper, which has 12mm plate running back to each chassis leg so forming a safe even pull on the nose. If I was running the std bumper, Id be looking to find a couple of decent Jate style rings that could be bolted on using the front spring bolt.. Not ideal, but when used together with a triangulated strap they'd be very strong and pulling evenly on both front chassis rails. I think tho, with your decent tyres, and a bit of weight in the rear with all the camping gear, you will be surprised where a 101 will go. I'm yet to get mine stuck to the point where I can't drive out without help!
    Hope that helps, and interested to hear what others think..
    1995 Mercedes 1222A 4x4
    1969 (Now know! Thanks Diana!!) Ser 2 Tdi SWB
    1991 VW Citi Golf Cti (soon to be Tdi)
    'When there's smoke, there's plenty of poke!!'
    'The more the smoke, the more the poke!!'
    Dec 2009
    Even something done like this on the two front spring eyes would be fine.. Yeah, I hear all the 'it's home made' etc etc, but, I would rather something I've made under there than the unknown quality of a Chinese part that I ordered to c if it'll do the job.... If its done by a coded welder or engineer, it should be fine.
    I for two 4500kg hooks in the front bolted through the front spring hangers. They are bolted on the outside of each chassis spring hanger and I use a bridle between the two so the general pull is inward on the stronger area of the hooks. Seems to work OK and is cheap to do and given the spot is so so reinforced crush tubes are not needed for the HT bolts.
    Front
    On the rear I use a recovery block in the receiver hitch. Prior to that. I just used to snatch off the smaller hole to the left of the rear cross member. As mentioned it all comes down to how much confidence you have in the strength of the rear cross member. In theory it is strong enough but with a fee years and a bit of internal rust things may be different.
    When I get energetic I might mount recovery points on the inside rear of the chassis rails (with crush tubes).
    Rear
    Thanks guys. I have the nato hitch and its in good condition so will get it repainted and remounted. For the time being I will look to get some recovery hooks in the front like yours Garry.
    The front bumper sounds great Simon. Some years down the track (when I have a proper workshop, not a driveway) I'd like to have a crack at making up a new front bar.
