Results 1 to 6 of 6
Thread: Swivels - CVs - 101s
    Working on my brakes I have spotted that the the filler plug on the 101 swivel hubs has had grease nipples put in them - so clearly the previous owner has been using grease.
    No discussion on benefits of oil over grease and vice versa please - it has been done to death.
    Now on my old subaru CVs I just used to use high pressure CV grease - a yukkie molybneum (I know spelling) dark grey grease - worked fine.
    So my questions are - given each hub is speced for 800ml of oil, if I use grease instead will the stuff I used in my subaru be OK and how much should go in.
    What is the best product to flush the stuff that is in there out so I can put in either oil or grease (haven't made my own mind up yet).
    Ok - to get the discussion going - lets have another discussion on the pros or cons of oil vs grease
    East-South-East Girt-By-Sea
    1.20 MB
    Oil gives better lubrication until the seals start to fail, or more importantly the balls become scored (which on a 101 can be a problem).
    I know that the Penrite Oil, US site previously recommended semi-fluid grease for Land Rover swivels but can not find the old link.
    It comes in a cartridge for use in a grease gun, so having the grease nipples would be required.
    Diana
    Last edited by Lotz-A-Landies; 21st February 2008 at 05:13 PM. Reason: "Penrite" spelling
    Jan 2008
    Nowra NSW
    OK I will bite.
    My 101 is running EP90 in the CVs and only has a slight leak after a hard high speed run.( I do have some pitting due to stone damage)
    The british RAEME report in the 1970s started to touch on the use of grease in the CVs of a 101......given garrycol the web site.
    Mobil make a special grease for steering boxes and is a semi fluid over a wide temp range.( I cant remember the name)
    If the the grease is clean and everything is working OK.....why fix it.
    I am leaving the oil in my 101 CVs for the same reason.
    Just remember the grease nipples will allow easy over filling with a power grease gun.
    I would just fill the CVs up using the end of the grease gun in the filler hole without the plug and grease nipple.
    Regards.
    Quote Originally Posted by 101 Ron View Post
    OK I will bite.
    Regards.
    Working on the brakes - I just noticed the grease nipples.
    As far as lubrication goes I have only changed the engine oil and filter at this stage.
    After the brakes are fixed, the next job is replace all the other oils and grease etc - so I want to change whatever is in there - don't actually know at this stage though passenger side swivel has some serious weepage so if it has grease in it - it is a bit of a worry. I suspect it was leaking oil so the change to grease and some oil is still in there with the grease - the job for next week.
    Jan 2008
    Nowra NSW
    [I] have never had my CVs apart, but there could be a oil seal leaking between the the diff and the CV causing the CV to leak.
    I found on the front drive shalf to the diff the transfercase seal leaks as the normal vibs due to the high unijoint angles.
    The drive flanges wear a bit on the splines and the fix was to use a speedy sleeve just to tighten up the seal a bit better. where it runs on the drive flange[/
    Check the oil cooler hoses from the engine to the cooler as they have been known to fail due to old age.
    Pirtek or similar can make them for you.I]
