Results 1 to 10 of 28
Thread: TD5 warm up
    Jul 2007
    Brisbane North
    TD5 warm up
    Do you warm up your td5's?
    I know in petrol engines there is a lot of debate. As for diesels Ive no idea.
    99.87 MB
    No.
    I think the trend is for engines with engine management should be just gotten in and driven, but don't shut them down hot if turbo charged.
    Slunnie
    tombraider Guest
    Quote Originally Posted by Aaron View Post
    Manufacturers of modern vehicles now say drive of smoothly till up to normal temp...
    No debate... Simple! Factory says so!
    I start it and give it 5-10 while I put my seatbelt on. Then I drive off gently. As Toomby says, as per factory recommendations.
     2005 Defender 110 
    99.87 MB
    Quote Originally Posted by Captain_Rightfoot View Post
    It really shouldn't take that long to get your seatbelt on. In that time I've started, driven to work, parked and turned off.
    Slunnie
    Ferntree Gully VIC
    dont warm mine up
    always in to much of a hurry for that
    130's rule
    i do about the same, start it, plug the phone in put the belt on, reverse out the drive way and then ease away... (as much as one can ease away when you hav e all the beasties of hades trapped atop your pistons crowns)
    Jul 2007
    Brisbane North
    Im the same. I used to do it to my BA Falcon, and I ended up with a filthy throttle body.
    Feb 2006
    gosford
    About the same for me to.
    Brisbane, Inner East.
    Detroit Diesel Operators Instructions always said to fire them up and get into it. Warm up not necessary.
    URSUSMAJOR
