Proberly Ironman but do a search on here you never know what you'll find
Adam
Hi All,
Just wondering whats the cheapest 2 inch lift for a D2. I dont want to lift more then 2 inches and dont want to pay big bucks (hundreds of dollars) for a lift kit. Whats out there and how much do i need to pay. thx
Adam
Just remember you get what you pay for
If its a matter of a few hundred dollars save the extra cash
as you will regret cheap stuff later on![]()
OME springs, with OME or Pro Comp long travel shocks.
Baz.
Cheers Baz.
2007 BMW R1200GS
What springs and shocks do you currently have in it?
If you've got at least aftermarket rear shocks, then just replace the 4 coils with King or OME.
Slunnie
Hi
I got an EFS +50mm spring and shocky set from 4WD Direct - 4X4 Suspension and Accessory products for most of the popular Aussie 4WDs, SUVs, AWDs & UTEs.
They were substantially cheaper(ie hundreds of$$$) than all the quotes I got and included delivery to my door(handy as Im in a country town)
The kit is quite stiff compared to the marshmallow ride the worn out 200000km standard stuff had,articulation is good.
Fitted myself,easily done but you definately need to hire/buy/borrow a spring compressor!!!!
There is somebody else with a Disco on here mentions having EFS suspension in their signature.
Andrew
DISCOVERY IS TO BE DISOWNED
Snow White MY14 TDV6 D4
Cheapest lift is coil spacers. Depends on what you are trying to achieve with the lift. Cheap often costs more in the long run
2" coil spacers will also need 2" longer shocks which on a D2 also means longer everything else like brake lines, ABS lines, Xmember spacers, bumpstops etc.
Slunnie
