Results 1 to 4 of 4
Thread: Instrument Binnacle Removal Discovery 1995 series 1
    There's an annoying buzz behind the instrument binnacle for the life of me I can't see any visable screws or clips to remove to take it off. I don't want to force it off don't want broken clips.
    Thanks in advance
    Dalby
    To get the surround off there are two screws above the steering column at the bottom of the surround. Remove these and thenthere are two clips on the top near the windscreen. Pulling forward should release those two easily.
    As for the instrument cluster thingo itself there are a couple of screws in there. I've had it out but don't remember where the screws are exactly. Probably one in each corner.
    Kyabram, VIC 3620
    Quote Originally Posted by Cool95 View Post
    Thanks in advance
    See attached
    ..................but I would recommend that you buy the RAVE CD from the markets section, it has all this info in it, and they are not expensive..........
    Plus the sales of these helps support this forum
    Ladas
    Thanks for the location of the screws and clips
