Results 1 to 6 of 6
Thread: SRS light on
    SRS light on
    Hi, this car is killing me!!!!!! Just finished changing steering box seal and put everything back together to find the SRS light remains on. Not sure what I could have done to cause this as I didn't muck about with any wires. Once again any suggestions. 1998 Tdi 300 auto
    Somewhere else, QLD
    Time to visit somebody who can read the fault: In the meantime, see if a fuse has blown - if SRS doesn't get power, that can trigger the light.
    check that you didn't knock the plug to the accelerometer. I think it is on the chassis rail by the steering box.
    Code reading is helpful, but they charge you 80 bucks for that.
    Mine came on when I killed a battery. Didn't reset when I put a new battery in.
    Code returned was "battery was or is low voltage" 80 bucks to reset that >
    Wollongong
    Quote Originally Posted by Bill Flyer View Post
    Being a 1998 model also means that your SRS is due for a service, which I believe is quite expensive. My 95 disco's SRS light came on in 1995 and is still on. I had it reset while it was in for a service, but it came back on again 3 days later.
    Williams West Aust
    In the D2 the problem is usually the wiring under the front seats,normally the drivers one.
    You just unplug clean the connector re-plug.
    Worth a try.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    St Helena,Melbourne
    4.28 MB
    Quote Originally Posted by chunk View Post
    15 years is the updated replacement period.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
