Results 1 to 10 of 13
Thread: Electrolux 3 way fridge?
    Hamilton,Vic
    Hi All,
    Just wondering if anybody knows much about them?
    We are going to use our '96 Jayco Pelican for the first time over the weekend. We are leaving early in the morning but having issues wit hthe fridge temp.
    As it says on the label I turned it on and turned the thermostat knob a 1/4 turn and it went to work. But now it sems to be having issue's getting below 10 dec.
    So my main question is on the thermostat knob is the lower the number the colder it is or the other way around?
    It go's like this on the knob;
    max 6 5 4 3 2 1 off I cant remember what the highest number is but you get the idea.
    So when I do what the label says its on about the 3.......
    any help please? the wife is starting to panic about the bloody milk !
    Williams West Aust
    Get her some UHT milk.
    I would be alot more worried about the beer being too hot!!!!
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Nundle
    Max is just that........coldest. ie the higher the number, the colder the fridge should get.
    Numpty
    REMLR No 143
    Melbourne, outer South East
    Andrew, make sure it is perfectly level
    Recommend you take a small spirit level for the purpose.
    Hamilton,Vic
    Andrew
    one step ahead of you bud ....the beer is in the Weaco, in fact we have two a CF-60L (his) and a 21L (hers)......
    Hamilton,Vic
    Quote Originally Posted by numpty View Post
    Ok thanks mate, I thought that was the case but I had to be Shaw to be Shaw......
    Hamilton,Vic
    Quote Originally Posted by waynep View Post
    Thanks for the tip, we have one of those small levels on the draw bar, and its sitting level lengh ways but a tad high on the left side........its one of those "T" levels....if you know what I mean.....
    In Katherine, I found with my Electrolux 3 way built into the camper that two concrete pavers too high on one side was enough to stop the fridge working efficiently.
    Running on 240 and set on 3, water bottles in the freezer were slowly defrosting after a day or two.
    Two pavers under one wheel made it perfectly level. In no time at all the water bottlers were refrozen, even with the setting back on 2.
    i reckon I can get away with one paver off level, but obviously not 2.
    Feb 2005
    12 year old fridge......how long has it been sitting around
    you might need to take it out and turn it upside down to free up the stuff inside the tubes...cannot remember the name of the stuff, this is what a local repair told me to do
    seemed to work
    i also took the freezer door off
    NSW far north coast
    seemed to work
    The procedure actually goes something like, tip onto the boiler side first and wait for the gurgling to stop. Tip upside down and wait for the gurgling to stop. Tip onto the other side (and wait for the gurgling to stop) tip back onto it's top, lean over at 45* and shake the begeezus out of it.
    Tip back onto it's feet, wait for the gurgling to stop and then turn back on.
    You are re-mixing the ammonia, bromine and water.
    But with Andrew's already down to 10*, it may not be a mix issue.
    How's the temp this morning, Andrew ?
    And did you have it running on 240V, 12V or gas ?
