Thread: What Next: 109 IIa Rear Differential Shaft Failure
    spencerbrookfarm Guest
    Hi, I have a 109IIA ex fire truck which we use at the farm with a 8M folding spray boom for spraying the paddock. The spiggot where the drive shaft attaches to the rear differential has just broken off.
    I'm no expert on fixing up vintage vehicles - clueless in fact. My local garage said if I bring the parts he'll fit them, but where do I start looking? What do you think would be a sensible next step:-
    a) scrap the vehicle
    b) send the broken diff to be repaired
    c) buy a second hand diff
    Any advice would be very welcome, best regards
    neil
    gumby190 Guest
    Forget about suggestion A.
    2nd hand diffs are pretty easy to come by, just have a look in any wreckers that are near by, other than that send him to get fixed.
    Pictures are good too..........
    Tommy Guest
    Neil
    Send me a PM or call me on 0400 934 782 as I should be able to help you out.
    Stuart
    Buy a second hand diff.
    Note that unless it has been changed it is a Rover differential, 4.7:1. These are either the same or at least interchangeable for almost all Series Landrovers 1949-83 (except very early ones, lwb Series 3 rear and Stage 1 V8 & Isuzu) and are the same front and rear. As a result, second hand ones should be readily available, and I would be surprised if someone on here does not have a spare one (I do, but I am a bit far away from you).
    Changing the diff should take no more than a couple of hours even if you have never done it before, and can be done with only spanners, although a concrete floor and a floor jack helps.
    Cessnock NSW
    G'day All, If you lived over here in the East and not the West, I would give you a couple and show you how to do it, it is as JD has said very easy to do cheers Dennis
