Results 1 to 10 of 16
Thread: Replacement carby
    Nundle
    Replacement carby
    Does anyone know where I can source a replacement carby for a S1 in or around Brisbane. I understand that all S1's have the same Zenith, with different jets for different engines.
    The carby on Leon, (a Zenith) is not the right one, and uses more fuel than I believe it should. And yes, I know they can be thirsty. I have been given the name of a company in Sydney that I will try on Monday (Indian made Zenith) but was hoping for something closer, as I'd like to have it fitted for the trip to Cooma.
    Yes I know there are a myriad of carby's that probably fit, but I would like to keep it as standard as possible.
    Numpty
    REMLR No 143
    East-South-East Girt-By-Sea
    1.20 MB
    Numpty
    The Series 1's all had a Solex 32PB carburettor.
    I have pasted the data of the jetting below - however it is out of format, so you will have to cut and paste it into another document. Or look at the page in the Trans Tasman Groups files section.
    There is a reproduction carby made in India under licence to Solex, however as it is set up for a WWII Jeep you need to fiddle with the linkages a little. Master Chief knows where they are available.
    Diana
    http://au.groups.yahoo.com/group/LRS...2032%20PBI%20/
    "1948-58 Land Rover carburettor types
    Source: Land Rover World"
    Year 1948-51 1951-54 1955-58
    Specification no. 1513 1560 1741
    Engine size 1.6 litre 2.0 litre 2.0 litre
    Choke tube 23 25 25
    Main jet 107.5 115 115
    Correction jet 160 170 240
    Pilot jet 45 55 55
    Pilot air bleed 150 150 150
    Emulsion tube no. 10 no. 10 no. 10
    Pump jet 50 75 75
    Economy jet 50 50 75
    Starter petrol jet 135 135 (150*) 135
    Starter air jet 5.5 5.5 (3.5*) 5.5
    Float 11 gram 11 gram 11 gram
    Needle valve 1.5 1.5 1.5
    Non-return valve
    * When engine governor is fitted to 1955-58 models, spec 1560 with alternative jets is used
    Last edited by Lotz-A-Landies; 9th March 2008 at 06:27 PM. Reason: Removed 2 references field sets to ease confusion
    Nundle
    Thanks Diana.
    Master Chief informed me Hiltons replacement carb on his 80" was an Indian Zenith. A mix up I expect, and yes, he did tell me where to get one and that's the one in Sydney. I will try them tomorrow.
    I've actually got an original on my 80", but think it's a little too far gone for the moment.
    Numpty
    REMLR No 143
    South Australia - Port Pirie
    Hi there Diana
    Your experties amaze me - you have just solved a little problem I have been having with the Fire Engine (running a little rough).
    When engine governor is fitted to 1955-58 models, spec 1560 with alternative jets is used * Engines numbered 860001 to 861871, except those with governor
    Theres different jets in the carby when the vehicle is fitted with Govenor.
    Wayne
    1.20 MB
    Quote Originally Posted by ellard View Post
    Hi there Diana...
    ...Theres different jets in the carby when the vehicle is fitted with Govenor.
    Wayne
    Wayne
    That is why we have kept the Yahoo Website for the TTS1 group - all there either in the files or the database sections. Always trying to add more.
    Diana
    WWII Jeeps, Ford and Willys, use a Carter carburettor.
    Aaron.
    1.20 MB
    Quote Originally Posted by Aaron IIA View Post
    Aaron.
    Aaron
    I have no idea if you are right or wrong about WWII Jeeps - however I have been told that it is set up for a Jeep, (I assumed WWII) with wrong linkages for the Land Rover. There is a thread somewhere with the modifications required for the conversion.
    Perhaps it is one of the Indian made jeeps of the 1950s and 60s who knows.
    Diana
    Nundle
    Well, I've had a look at the carby on the 80", and provided I can get a kit for it (4WD's in Melbourne list one), that might be the way to go. And yes, it is a Solex 32 PB, and with the jet sizes so kindly provided by Diana, we should be in business.
    Numpty
    REMLR No 143
    Hi there Diana
    Wayne
    Wayne - I have to agree with you there.
    1.20 MB
    Hi there Diana
    Your experties amaze me - ...
    ... Wayne
    Wayne and Garry
    Why do you think I have a bunch of "Experts" hanging around? (called the experties*)
    Actually it is most likely to old adage - "the empty vessel makes the most noise"!
    Diana
    P.S. * That one's for Ron "P38arover" otherwise it would be expertise.
