Results 1 to 10 of 14
Thread: Capstan Winch Rope
    Narre Warren South
    Capstan Winch Rope
    I thought I should get some rope for the winch fitted to my Series 1 so a visited a rope/chain/sling supplier in Dandenong, unfortunately they hadn't got a clue. I was a bit wary of the advice to use a steel rope ?!
    Internet research seems to point to a natural (manilla) rope but I wondered if anyone has any further information such as the best diameter, whether manilla is the best option etc. etc.
    When the winch was fitted as an option what did LR provide in the way of a rope ?
    Another thought is can you still source the shear pins ?
    Maybe a rope that 'is about right' wound in a figure 8 on the front bumper would give the right look ? Still it seems a shame to have a winch that cannot be used in anger..........
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    East-South-East Girt-By-Sea
    1.20 MB
    Quote Originally Posted by gromit View Post
    Colin
    Colin
    DO NOT USE A STEEL/WIRE ROPE. It will damage the bollard, you find many that have been used with wire rope and can see the grooves. Some even have hardfacing welded onto the bollard - Yuk!
    The best type of rope is hemp as it gives a better feel and grip over manila rope and from memory should be about 1 1/2" diameter. Try a ships chandler rather than a lifting gear specialist. (They may even splice an eye into one end for you to use your D shackles.)
    Diana
    Colin
    Diana
    Series 2a Owners Handbook p/n 4482 October 1962 p.100:-
    "The most suitable rope size and type is 1 1/4" diameter (31.5mm) 3 3/4" circumference Manila"
    Hemp would also be suitable. If used seriously do not use synthetic rope, or at least use it very carefully - if slipped on the capstan, as is normal practice for control, it is likely to melt on the surface and lose all grip, as well as substantially weakening that part of the rope.
    1.20 MB
    ...Still it seems a shame to have a winch that cannot be used in anger..........
    Colin
    Colin
    Is the comment that it can't be used in anger relating to the absence of the rope or something else?
    If something else is the absence of the engine side of the capstan, you can modify the series 2 selector and other bits. PM me an I'll give you the dirt on the issue.
    Diana
    P.S. When getting manila/hemp rope - I should have mentioned getting a thimble spliced in with the eye. This will protect the end of the rope from the D shackles etc.
    Sunny Pucka
    Colin
    Diana
    I have small grooves in my bollard from this.
    Some synthetic rope has a lot of stretch and if it breaks, it will whip back with some force.
    The thicker the rope the less raps around the bollard (min twice around) The thiner the more raps.
    I have 1 1/2'' manila. Its very long.
    As for the rope fig8 around the bumper.
    Cheers Easo
    1.20 MB
    Quote Originally Posted by easo View Post
    ...I have 1 1/2'' manila. Its very long.
    Cheers Easo
    Yup but if you use manila - ya canna smoke it wen ya wanna r'lax! Geez I've got da munchies rite 'bout now.
    Easo - are the spot lights on the 130 to enhance the family resemblance? Nice work!!
    Diana
    Sunny Pucka
    Diana
    Good evening, Diana.
    Now I see it! Never thought about it. A Roo recently took out the left one.
    Do you have any sheer pins? I need one, or two.
    Cheers Easo
    1.20 MB
    Cheers Easo
    Sorry Easo I don't - although I don't think they are all that difficult to acquire from engineers suppliers. Try someone like Blackwoods.
    From memory, in the capstan manual it suggests that in an emergency you can use a 1/4" mild steel bolt.
    Sorry I can't be all that much help.
    Diana
    Sunny Pucka
    The hard part is trying to line up the broken pin to knock it out.
    1.20 MB
    I think that is why so many end up with the mild steel.
    You need a fibreoptic endoscope so you can watch as you rotate the bollard.
    Diana
