Thread: Pto Winches
    Nov 2006
    cardiff ,NEWCASTLE.
    Talking Pto Winches
    ok i have a thomas pto 8000lbs winch.can any one point me in the right place to get hold of a manual owner or maintance.i am going to make a new frame for mine for the S3 & while its out i thought i would give it a spit & polish,but dont want to just jump in & pull it all apart..thanx...
    Feb 2005
    the manual was posted on here a while ago....do a quick search you should find
    i think i have a pdf somewhere that i could email
    Wheelers Hill, Melbourne
    I stripped one down a few years ago. Pretty simple to work on. I took the seals & bearings to bearing supplies and got newies.
    I recommend moreys oil when you replace the oil, or similar.
    David
    Brisbane, north of the river
    hmmm can't seem to attach to the message.
    Try doing a search on "Thomas" by me, should find the zip file.
    EDIT: Here is the thread: http://www.aulro.com/afvb/technical-chatter/48704-thomas-pto-winches-3.html
    Logan ( Brisbane)
    Good stuff that Morey's
    Quote Originally Posted by DeeJay View Post
    David
    I had a 30,000 Lb winch on a float that I use to drive, It use to leak oil and had what sounded like a bearing noise in it when pulling a heavy load ( dead earth moving plant) I filled it with Morey's and about 2 uses later the leaks and the noise went.
    Hodgo
