Hey everyone. What modifications would I need to do to fit 33x10.5x15 tyres to my 1970 IIA 88"?
I know 31x10.5's fit with relative ease, but would prefer 33x10.5 for the extra off-road ability, and I don't mind losing a bit of gearing.
If I need to raise the IIA above stock height, could I use 1 ton (or equivalent length) shackles on my 88"?
Thanks in advance![]()
1970 Series IIA 88"
1997 Discovery 300Tdi
Could you be more specific? Do you mean I will be breaking axles? If so, are stronger axles available to fit the standard housings?
1970 Series IIA 88"
I have broken rear axles on every series landrover I have owned and they all had standard wheels and tyres - so if you are going bigger wheels and tyres you will need to look at axles as a start and maybe diffs etc - someone else will have to advise options as I am no expert in this area - search of the forum might help.
OK, interesting, thanks for that. I Want to keep it relatively stock, hence my reason for asking about smallish tyres, and wanting to keep a stockish appearance, and stock drivetrain. Certainly gives me something to think about.
1970 Series IIA 88"
Mate , I am running 32x11.5x15's on my standard 109 and if driven like it's meant to can't see an axle breaking in a real hurry. But always a big possibility as they are not the strongest axle kicking about .
OK thanks. So that's a regular Land Rover rear diff, not a Salisbury?
Do you know if stronger axles exist? Also, I intend to install a locker, which I'm sure would be harder on axles.
Did you have to trim the guards or raise the body or suspension? Do they rub anywhere?
1970 Series IIA 88"
So is it a rover diff or a salisbury?![]()
