Results 1 to 10 of 19
Thread: Rim/Tyre Sizes for 03/04 D2's ?
    Toowoomba
    G'day All,
    Ok I have my eye on a 03 D2 TD5, 7 seater with 83000 km's. It is a stocker, never been off road and whoo hoo has 16inch rims ( ie my D3 had 18's and not much choice). Now my question is what is the rim specs for the 16's and what type of tyre sizes would suit with it being a stocker ( eventually will be lifted,chipped etc). Would like to have either BFG MT's or even their new AT's or perhaps other suggestions. Reason I ask is if I go ahead with this one, would get them to change tyres first and have it included in the price as opposed to the stock tyres they have on at the moment. Thanks in advance for advice/ tips,
    Stevo
    Heathcote Junction
    Stevo,
    You will get 265 x 75 x 16's on.
    They will rub slightly however when you lift it they won't rub any more.
    A heap of the guys on the D2au site run these tires.
    Be aware though that these tyres may be to big to be strictly legal as the new legislation talks about tyres only being 50mm bigger than the biggest stock tyre.
    Chuck
    Williams West Aust
    I run 235/85x16 MTRs on mine,2" lift.
    No touches at all,slightly taller than the 265/75,but narrower.No handling probs thanks to Mr ACE
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Gold Coast, Qld
    Yep, 265/75R16 seems to be generally regarded as the best fit for a D2 with a small lift. Also if and when you lift it, I have a complete set of 40mm OME springs if you want to get something on it quick. Happy to help you fit them plus can help you fit a washer to your steering stops as you will get slight rubbing at full lock. Of course you could go straight to 33"tyres like mine which are on a 40mm lift, but not ideal for a daily driver.
    Aye, Mick
    '99 Manual TD5 D2.......heap of money spent on it and it has ended
    Steveo,
    The rims will either be 16 x 7(235/70/16), 16 x 8(255/65/16) or 18 x 8(255/55/18) as these are the std rims fitted to the d2.
    As the guys have said & also on my D2 we run 265/75/16's,(I did run 235/85/16's on my Simpson trip but then thought thewider tyres were better) which fills the arches nicely. You may need to fit a B/Bar as if u dont you may get some rubbing on the wheel arch liners, the steering stops will also need to be adjusted out with washers to help stop rubbing too.
    Good luck & let the fun begin
    Toowoomba
    Thanks for the advice/ tips etc and Mick, yep might need to have a chat about the springs ,
    Stevo
    Toowoomba
    Ok a question in relation to lifts. Just got an email back from a bloke whom I was asking whether the D2 he had for sale was a 5 or 7 seater...was hoping 7 as it had all the work already done. He reckons that you can't put a lift kit under a 7 seater as suspension is different. Im assuming lift kit is a lift? I know the one Im looking at has coils upfront and SLS at rear. Is there an issue? Thanks,
    Stevo
    McDisco Guest
    Quote Originally Posted by stevo68 View Post
    Short answer....thats Rubbish!! He may be referring to the fact that its a air bag rear, but even this can be lifted with some blocks from 4x4intelligence.com.
    I dont think he really knows what can be done with a disco...
    Angus
    Steveo,
    Contact Simon at 4x4Discovery.com.au - "think outside ..."
    They have lift kits for the SLS version of the D2.
    They have a full kit of springs/shockers-front & spacers/shockers for the rear.
    If u dont adjust the rear air spring the vehicle sits down at the rear, if u adjust the height sensor u are running the air springs at a higher rate than normal, which in turn causes failure.
    The spacer sits in between the air spring & mount giving the vehilce a normal ride height & putting the correct amount of pressure into the air spring & letting it do its proper job.
    May 2003
    On The Road
    you can get over-length bags,, which give 3" more travel. Using a block at the rear partly solves the longer overhang of the D2, but doesnt increase articulation.
