Results 1 to 10 of 26
Thread: The house or the defender?
    Hey guys,
    Just bought a new house. The garage is a double tandem with an inspection pit and workbenches at the back!
    Problem:
    Roof 2.05 m Defender currently 2.3 m!
    What do I do?
    Buy a set of old 29 disco tires and rims for when I want to work on the car or modify the garage?
    Garage door is easily removed and remounted higher but the cross beams in the garage would need to be removed and rebolted higher up the rafters.
    May 2006
    Carlton, Melbourne
    Change the house.
    Only need to do that once, changing wheels everytime you want to work on the car will get really tedious.
    But you knew the answer to begin with, didn't you??
    Fraser
    How did your 'fender get so tall? What are you feeding it? Mine's only 2.05 (without roofracks) - still wouldn't fit though.
    Feb 2005
    the house
    Mar 2007
    When I was renting I used to let my tyres down so I could crawl into the garage, then pump them back up on weekends. It got real old real fast.
    I'd modify the house. Just go way bigger than you think you need to. Also, try to put in a longditudinal "I" beam with pulley block down the centre so you can easily move engines/gearboxes/axle assemblies/pianos up and down with almost no hassle.
    kermit31 Guest
    Very simple lower the ground level ???
    St Helena,Melbourne
    4.28 MB
    Quote Originally Posted by kermit31 View Post
    Now theres a thought, dig it out so you drive down and in.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Lower floor?
    Maybe not!
    The issues are:
    Sloping concrete driveway into Garage:
    Hardyplank cladding - need to move one plank and refit roller door 2/3 inches up.
    Roof is Triangle shape with beams sitting on frame of the house and cross beams across the garage.
    Building inspector reconned cutting the cross beams making them an inch or so shorter and rebolting a couple of inches up the roofing beams?
    Anybody see any issues with this?
    My other question is will the roller door have the excess space to roll further down?
    Lower floor
    Dig out two channel for the wheels to sit in, 2 inches deep. 1 day job with a jackhammer and an angle grinder with cutting disc for thew reo
    Sunny Pucka
    Sell the fender and get a series, then you can un-bolt the series roof. Plently of room then.
