Results 1 to 4 of 4
Thread: Water leaks in "98" 110 defender
    I know this is a common problem with the defender. when it rains i get water running out from under the roof lining in both front door conners. i was thinking about replacing the safari window rubber... see if that fixes the problem? But i was wondering if people have ever had problems with the external roof joins? I so what did you do to seal it?
    brisbane
    check out my previous post about this
    & you'll find the water ingress manual for defender posted by grizzly adams.(much thanks again for this glenn!)
    every leak they know of!
    Sandstone Point Qld
    Thanx for the post on the Manual saved and printed
    I have found a few leaks but I didn't know of the other ones, but it is a defender thats why they sink and not float ...
    Cheers again Azza
    Thanks guys... So just a normal silicone sealant on joins. What did you use on the rack in the gutters?
