Some info on whether it has and hasn't got the internals, you need to look at the Transfer Case serial number, not the G/Box serial number
The early Disco II"s were not supplied with a centre diff lock function for the LT 230 transfer case but this has recently become an option when ordering a new vehicle.
The first Disco II"s had the diff lock capability on the transfer case but this was then phased out on the later ones.
We are able to supply both the factory linkage assembly and the parts to convert the transfer case if required.
The linkage is easy to fit, cable operated and very neat.
If you have the diff lock stud on your unit you will only require the linkage parts, to determine this you will need to find the transfer case serial number and check it starts with either 41D or 42D.
If it starts 61D, 62D, 69D or 70D then you will need the diff lock parts to go in the transfer case which are an additional £ 225. Click Here for a photo of these parts.
Baz.
Cheers Baz.
2007 BMW R1200GS
