Thread: Series One water pump kits
    South Australia - Port Pirie
    Hi there all
    Just in the process of re-birthing a couple of spare water pumps - and can not justify the price of a new one.
    There only a shaft - impellor and mechanical seal - can anyone help with a company whom may be able to provide the kits.
    Thanks in advance
    Wayne
    Oct 2003
    Godwin Beach Qld
    G'day Ellard
    Have a talk to Easo, he may be able source repair kits at a reasonable price in a couple of months
    Wayne,
    As a suggestion, disassemble one and take the shaft assembly (impeller presses off) and seal into your local bearing specialist and see if they can come up with replacements, even if they need, for example, reboring or bushing the impeller and fan hub. Even the impeller may be replaceable by another one. Likely candidates would be ones for any contemporary British engines such as Vanguard or Ferguson etc.
    Hi there
    I didnt think of easo - as he is heading over to the UK shortly.
    As for other kits - a fergy tractor ones are $35.00 same shaft but have more rotors on the impellors (dont think that will be a mjor issue) - the seal is a slightly loose in the housing, might work but would preferr a bigger seal.
    Its a lot of headaches but a new water pump range from $300 - $400 where a kits is around the $40 mark - hense my reason for trying a retrofit........
    JDNSW - will do a trip to our local auto place tomorrow - and try and source a seal......thanks again
    All the best
    Wayne
    Quote Originally Posted by ellard View Post
    All the best
    Wayne
    Wayne, I would try a bearing specialist rather than an auto specialist, although both are worth a try. The bearing specialist is more likely to be able to look for something by dimensions, where the auto place is more likely to only be able to look by model, but if they have someone very experienced he may know straight off what works.
