run up to 35's on mine - what did you want to know?
has anyone got 235/85/16 or 33/10.5/15 tyres on their disco... would like some info if I can![]()
thanks for the reply
what width rims and what offset are they
what size suspension lift and/or body lift do you need to get clearance
how much clearance do you have under the diffs
did you have to cut the front guards for clearance
did you have to fit flares to cover the tyres
just a few thingsthanks
Come and see my new Maxxis 235x85x16 in my Rangie and see if you can fit the spare. They are just bellow 32". the ones in your disco are 31"
They cost me $ 195.00 ea
G'day Mark,
I tried 235/85/16s on my disco but found they rubbed too much at the rear, thats with about 2.5 inch lift included spring spaces which would act a bit like extended bump stops. The front was ok because the springs are too stiff, with the springs I want in there it would be a problem. I think with a 2 inch BL they will work ok. You do notice the gearing with these tyres as opposed to the 245/75s.
Pete
2008 Range Rover Sport TDV8
1973 Range Rover Classic "Suffix B"
I chucked some 235x85x16s on offset rims on my disco with no problems.
Car has ~40mm springs and 50mm body lift.
You need to run offset rims.
I have also not touched to trimmed anything with this set up, no rubbing at all.
how far offset are those rims Dave
No idea, but a fair bit - they are basically reversed series rims.
The rears are offset about 10mm more than the fronts
I'll try and measure sometime in the daylight this week.
Dave.
Hey Shorty, from what I understand (and I could be wrong!) LRA sell Sunny style rims with a 1" offset for $99 ea... but I have read somewhere were people have made offsets of 80mm+, but these are for 12.5 wide rubber.
So mate, are you trying to tell me something here??? hehehe
Carlos
1963 Land Rover Series 2a 88
Mines D2,yep no probs,overgeared a bit!!!,The D2 has better wheelarch clearance than a D1.
See Agrojnrs pics in "show us your Discovery" He has them on a D1.
Andrew
DISCOVERY IS TO BE DISOWNED
Snow White MY14 TDV6 D4
