Thread: Petrol to Diesel fuel tank
    Jun 2007
    Does anyone have a photo of the top of a diesel tank? I have a petrol tank I need to drill a hole for the return line and I need an idea on position
    WA
    Doesn't really matter where - highest point on the tank is best - somewhere near pickup hole.
    I have fitted return lines to 4 fuel tanks, never had a problem.
    Usually just silver solder some copper tubing into the top of the tank, but had some custom tanks made, and got a 2nd pickup hole - about 2" away from the normal one.
    Yinnar South, Vic
    Silver solder or soft solder, just wondering, flame go boom and all
    WA
    Quote Originally Posted by rovercare View Post
    Yeah - usually have soft soldered for that reason. But if it is a diesel tank and/or the tank is clean, I have silver soldered. If I remember rightly, that last one I did I cleaned, then filled 99% full with water, soldered, drained water and flushed with metho.
    Yinnar South, Vic
    That was the disclaimer I was expecting to be used with the flame element that's why I thought you might of meant soft solder
    WA
    "Where's the kaboom? There was supposed to be an EARTH-shattering kaboom!"
    -- Marvin Martian
    I have converted a LR petrol tank into a deisel tank. I did this by putting a "T" piece into the breather line for the return. This works quite well, and there is no modification to the tank. But if you insist or fitting a "proper" return, here is a real diesel tank.
    Aaron.
