Results 1 to 8 of 8
Thread: Rims
    Nov 2006
    cardiff ,NEWCASTLE.
    Smile Rims
    hey guys can someone tell me forsure if sunraysia rims 15x8 off a series 1 DISCOVERY will fit my LWB series 3,i have seen some & realy want to buy them just wasnt 100% if they would fit..someone has to know forsure...thanx heaps...
    Cessnock NSW
    G'day All, I cannot see any reason why they wouldn't cheers Dennis
    WA
    YES!
    (I have disco 1 steel rims on my SIIA (with SIII hubs))
    Apr 2007
    Central Coast NSW
    x 3
    Yep, the Pitch Circle Diametre (PCD) is the same, so they'll fit on the studs. If they're wearing 31x10.5x15 tyres you might find they'll poke out the side about an inch - good for spraying mud all over the place but a little untidy
    Nov 2006
    cardiff ,NEWCASTLE.
    Thanx guys.um what hapend to the thanx button in the bottom right of posts or was i just dreaming that...but thanx again guys i think i will bid on them now..
    Mar 2007
    You may also need to adjust the lock stop bolts, depending on how much tyre rub you get on full lock. It is a very easy job though.
    Good luck with the bidding, but don't get too enthusiastic. Sunraysias aren't too expensive new and come up quite often.
    yes
    St Helena,Melbourne
    4.28 MB
    And i have series sunny's on my rangie, 15x8 and the front rims with 1" less offset so you can steer the blooding thing.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
