Results 1 to 4 of 4
Thread: Caterham Vs Atom
    May 2003
    On The Road
    Caterham Vs Atom
    The new performance level for supercars is---
    500HP per Tonne,,,
    and this thing only weighs 500kgs,,,,
    Filed under: Convertibles, Euro, UK
    Click above for a high-res gallery of the Caterham R500.
    After getting teased and then leaked on, we officially have details on Caterham's new Superlight R500. The stats are as insane as we predicted, with a naturally aspirated 2.0-liter Ford Durtec sending 263 hp and 177 lb.-ft. of torque to the rear wheels through either a six-speed manual or a six-speed sequential gearbox equipped with launch control. With 520 hp per ton (it weighs 506 kg, or 1,116 pounds) the R500 can rocket to 60 in exactly 2.88 seconds, but that's only part of the performance equation.
    Caterham fitted the R500 with a "Carbon Induction Airbox," Eibach springs and dampers pulled from the C400 Caterham racer, four-piston calipers in front and two-piston rotors out back, Avon C500 track-day rubber, and replaced many of the components with aluminum and carbon fiber to shed 9 kgs from the chassis. The R500 is also equipped with a new electronic IP nestled into a full carbon fiber dash. If you're in the UK and have £36,995 to spare, you could do worse for you next track-day excursion.
    Make the jump for the full press release.
    Gallery: Caterham R500
    99.87 MB
    Sounds like it'd be an awesome car to drive!
    But the hype is certainly second rate, with new carbon induction, 9 kg shed from the chassis, eibach springs etc.
    But, the rest of it does sound very very yummy!
    Slunnie
    I will own a caterham one day
     2005 Defender 110 
    May 2003
    On The Road
    I'll bring the beer,,,
