Thread: Whats this plug meant to connect to?
    Jul 2007
    Brisbane North
    This is under the drivers side guard to the right of the power steering close to the firewall.
    Maleny, Queensland
    You REALLY need to get a RAVE CD. It has pictures of every connector as well as the wiring diagrams. I'd look it up myself but need more info on where the brown wires trace to - plus I just can't be 6uggered .
    Maleny, Queensland
    OK, I felt guilty about blowing you off there so I had a look in RAVE myself. I can only find one connector that has both brown-green & brown-white wires into it and that is a resistor for the headlight dimmer-dip circuit.
    You had the headlight wiring loom upgraded with a Traxide setup didn't you. Maybe that's now a left-over.
    Jul 2007
    Brisbane North
    Im unable to find it on Rave. Upgraded loom still isnt installed. Everything works fine in the car (including the heater!)
    May 2006
    Carlton, Melbourne
    It could be anything really, my money would be on one of two things depending on where it is exactly:
    Heated windscreen (if the wires are quite thick)
    or
    electric windows If it's a defender without them.
    Fraser
    Ejector seat?
    Seriously, maybe a bigger photo of the general area and I'll go down and have a look at my car if you like....
     2005 Defender 110 
    Maleny, Queensland
    Quote Originally Posted by fraser130 View Post
    Yep - that sounds possible. The heated windscreen doesn't show up in RAVE but we all know they were available for Td5s from 2002 onwards.
    Apr 2007
    Ipswich QLD
    Abs?
    Jul 2007
    Brisbane North
    I was thinking a factory option not fitted. Ill try to get a better shot at it on my next day off.
    Yass NSW
    Maybe thats for the anti lucus fault unit?
