Results 1 to 10 of 14
Thread: Leaking 2a
    Dante Guest
    Leaking 2a
    Hi guys,
    after returning from a 8 month holiday overseas I was getting my 2a (ex-Army, 2 1/4 Petrol) ready to bring back from Central Queensland to Brisbane.
    At the shops I notice a big green lake under the car, open the bonet and find a waterfall ;-) coming out of the RH rear of the engine block.
    Some sort of plug seem to have gone missing, I can not detect any thread and strangely enough the hole is not round. Well the hole itself is round, but whatever fits in there has to be the figure of an eight.
    I found in the forum a picture of an engine block and have circled the plug which is missing. (I apologize to the owner of the picture for using and altering his picture without authorisation).
    Now ... what kind of plug am I missing here. Any suggestions on how to fix this temporarly. I tried a 50cent piece with putty to the outside of the hole, it lasted about 500m.
    All I know it is not a welsh plug ;-)
    Any thoughts ?
    Thanks,
    Dante
    Last edited by Dante; 18th April 2008 at 06:12 PM. Reason: Added note about Welsh Plug
    Dante Guest
    Ok .. replying to myself ... looking at information
    Land Rover parts - WELSH PLUGS - 2.25 PETROL
    I deduct that part 527269 is still in place (that is why I don't have a thread) put it has a hole.
    I am now worried that it has a "Whitworth" thread. How easy would it be to find a replacement in the middle of the night. Provided I can get it out
    Any thoughts on this ?
    Thanks,
    Dante
    Cessnock NSW
    G'day All, The plugs you are refering to are of an alloy construction and the thread is 1" x 16TPI Conduit, the plugs are readily available thru the usual suspects. You will have strip down parts of the engine like in the picture and job made easier by removing LHS guard have fun cheers Dennis
    PS I have taps and I would suspect someone in that part of the world will have them as well.
    Dante Guest
    Hm .. won't be able to do any of that for now.
    I think I will get a high tensile bolt (short), and weld it into that plug. This way I should be able to undo it when needed.
    Not sure I would be able to remove it the easy way as the one of the extractors is quite rust and on the other side I am not sure I would be able to remove the plug that easy.
    Let you know how it goes.
    Thanks,
    Dante
    Emerald
    mate whereabouts in central qld are you? close to emerald?
    Cessnock NSW
    G'day All, I'm no welding expert but I'm certain you cannot weld steel to cast iron, so best of luck mate Dennis
    PS and you will really bugger up your block.
    Oct 2003
    Godwin Beach Qld
    G'day Dante
    That looks very much like the "Plug for Redundant Heater Hole" (Part No 527269) an alloy plug that screws into the Block and yes, it has 2 lugs in it which makes it look like a figure 8 when corroded away.
    BUT that looks like you have a hole in the block alongside the plug if so the block is a throw away is the hole in the block???
    That plug should be available from FWD motors in Brisbane (07 3848 9323) or British Off Road at Forrest Glen Qld (07 5445 1094)
    Oct 2003
    Godwin Beach Qld
    G'day Dante
    Sorry I misread your post that is NOT YOUR BLOCK but a sample photo
    you cant "weld" it but you can braze it up however thats a one time fix and not something you want to do unless you have plans to pull out the engine and rebuild it in the near future.
    epoxy and alfoil also works but the same criterea apply.
    Cessnock NSW
    G'day All, That red circle wasn't there when I posted earlier either, otherwise I would have said it is 1 1/8" dia plug and I knew it wasn't your block and others have said fix it properly or why bother asking for advice
