Originally Posted by
EchiDna
I assume you are flying into Darwin on a discount fare from Tiger Airways or something?
most of the area you are talking about is still going to be affected by the buildup - it's going to be mid thirties or higher the whole time you are there and the closer you are to the coast, the higher the humidity (think 90%rh or more, I'm not joking!) without a moment of respite, there will probably not be too many flies but IMHO, it is considered just about unbearable for most of the locals (supposedly more than 1/3 disapear south for this season), never mind autumnal travellers form the UK
anyway not to put you off, but if I had only a month and it had to be in November, I'd get onto another plane from Darwin and head south for the Vic/NSW high country... november is typically too early for fires, and not so hot as to be unbearable (mid twenties during the day).
I'd say 90% or more of travellers to the northern 1/3 of Australia do so from May-September - for a good reason!
Lot of truth there, though the flies should have gone south too.
The worst 2 months of the year up this way are October and November. That said 2007 was actually quite pleasant, December was crap. Temperatures in Darwin and down to Katherine are going to be 35-40C, humidity will be high, cloud cover will be sparce, sun will be slightly to the south but almost overhead, UV radiation will be listed as extreme.
See this site: Climate statistics for Australian locations
