Results 1 to 6 of 6
Thread: Coil sprung suspension for a S3
    Torquay Victoria
    Hi everyone does anyone know if there are any coil spung Series 3 in the group. I am wantng to know if some one has already done this conversion. It would be good to talk about they problems incurred. You can get gal chassis in England but the supplier is not shipping overseas at the moment so if anyone has experience in this conversion please let us know. Adapting a series 3 chassis locally would seem a good alternative is there someone that does this conversion in Oz.
    Gilderoy, Victoria
    Cut down Range Rover chassis would be the way to do it.
    Then weld on Bulkhead outriggers from series chassis and put your series body on it. Then you have a V8 powered, coil sprung series "hybrid".
    Take a look at "A 4x4 is born". It is a great example of building a hybrid, although theres is 100 inch instead of 88 inch but all the info is there.
    Mick
    1999 Land Rover 110 Defender TD5 Cab Chassis
    1985 Land Rover 110 County 4.6 EFI V8
    1993 Track Trailer camper
    Williams West Aust
    For licensing ease you need to start with a coil chassis.
    Go the early Rangie,as early as possible so you can avoid emissions/ADRs imposed on new stuff.
    You then get a V8 with coils all round,disc brakes and easily complied.
    Your vehicle will be regoed as a Rangie as thats what the chassis is but will look like a Series.
    Contact Julien at Discovery Automotives(they advertise on here),he has a "Series Rangie" Hybrid he built.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    East-South-East Girt-By-Sea
    1.20 MB
    Quote Originally Posted by garryseries3 View Post
    There are several other alternatives.
    Buy a County or a Defender, which already have coils and you don't need to have them certified by an engineer!
    Fit parabolic springs (which is the cheapest alternative). Santana Land Rovers are still made with parabolic instead of coils.
    Just a couple of thoughts!
    Diana
    99.87 MB
    This is how I did it. What I did was learning and not very well executed but it takes some time to do it.
    www.slunnie.com - IIa LC60 coil conversion
    Something additional to consider, is the series axles are a lot narrower that coiler axles and you may find that the spring perches etc wont fit due to the narrow series track
    Slunnie
    Warburton, Victoria
    i'm thinking of rangie diffs under the Stage 1, but leaving Leafs.... then i can have 4whel discs............
