Results 1 to 4 of 4
Thread: New cruise control ECU for P38 - plug and play?
    Jan 2008
    Medowie, Port Stephens and Sydney
    Hey guys,
    I've been told that my cruise control ECU has had it and needs to be replaced. Not the most expensive thing in the world but i'm wondering if i can do this myself by purchasing the part online and swapping the old for the new - does anyone know if it's just a case of plug it in and go?
    found a cheap one here;
    Discovery & Range Rover - Cruise Control ECU - AMR1173 - eBay, Range Rover, Car Parts, Cars, Parts Vehicles. (end time 02-May-08 05:30:00 AEST)
    D
    Mar 2007
    Birnam Range, qld
    I know you can on the classics, not sure if it needs to be switched on by a laptop on the p38? have you tried opening the ecu and checking the soldered joints? just run a soldering iron over the joints and retry it, it worked for my soft dash classic. worth a try as its usually the joints going dry that gives more trouble than the components on the board.
    neil
    Before you go fiddling with ECU's on your P38, it is a very common problem that the small vacuum hoses for the CC in the engine bay perish and need to be replaced.
    I will assume you have checked all of these already, but if not you should.
    I fixed up my cruise control for the princely sum of $4.50 using vacuum hose bought from SCA.
    If it is definitely the ECU, I would check with TRS in SA, they usually can supply most parts second hand at reasonable prices.
    Good luck
    2011 Range Rover Sport SDV6 Autobiography
    2004 Freelander TD4 SE
    1997 Range Rover 4.6 HSE
    1994 Range Rover Vogue
    derpomz Guest
    no light
    I have no light on my dash for my P38. Would a vacuum hose leak cause this problem or should i get a new ECU. Cant figur out why my cruise wont work, new owner by the way.
    If i get e new ECU, where oin earth is it and is it easy to replace.
