Results 1 to 4 of 4
Thread: TD5 Engine
    NSW , Pennant Hills
    TD5 Engine
    Hi Guys;
    This is more of an information brief I found on the web and wasn't sure where it should be posted up with regards to a TD5 engine , but it may/maynot make interest read for some of you TD5 owners.
    tech - Td5 diesel engine
    Contents
    * Introduction
    * Engine specification figures
    * Engine construction
    o Cylinder block
    o Fracture split con-rods
    o Flywheel
    o Cylinder head
    * Fuel supply system
    * Oil pump
    * Electronic unit injector (EUI)
    * Oil filter
    * Turbocharger
    * Cooling system
    * Auxiliary drive belt
    * Crankcase ventilation
    Key features of the engine include:
    * Five cylinder engine configuration
    * Cast iron block with aluminium cylinder head and structural aluminium
    engine sump
    * Overhead camshaft with a single rocker shaft
    * Hydraulic lash adjusters with independent finger followers
    * Electronic unit injectors
    * Timing chain and chain-driven oil pump
    * An aluminium lower ladder frame, incorporating the oil pump
    * Centrifugal oil filter
    * Fuel cooler
    * Integrated oil cooler
    * A new engine management system
    * Sequential cyclone engine breathing system
    * An integrated vacuum pump with the alternator
    * Cubic capacity 2498cc
    * Piston stroke 88.95mm
    * Piston bore 84.45mm
    * Compression ratio 19.5:1 � 0.5
    * Maximum Governed rev/min. 4850
    * Maximum rev/min (e.g. overrun) 5460
    * Target idle speed >0�C 740 rev/min.
    * Target idle speed <0�C 1000 rev/min.
    * Maximum torque (manual gearbox fitted) 300 Nm
    * Maximum torque (automatic gearbox fitted) 315 Nm
    * Maximum power New Discovery 101.5 kW @ 4,200 rev/min
    Defender 1999 MY 90.0kW @ 4,200 rev/min
    Engine construction
    The engine is an in-line five cylinder, turbocharged direct injection compression ignition unit. The block is
    of cast iron construction with an aluminium cylinder head. The engine uses �through bolt� technology. This
    provides excellent structural support and rigidity. An aluminium ladder frame secures to the bottom of the cylinder
    block to enhance the lower block rigidity. The ladder frame also incorporates a rotary oil pump. This oil pump passes
    pressurised oil through the aluminium ladder frame into the cylinder block. A gasket seals the ladder frame oil gallery
    and the cylinder block oil gallery. This gasket must be replaced whenever the ladder frame is removed.
    Cylinder block
    The cylinder block incorporates oil squirt jets which are used to cool the pistons. Each squirt jet incorporates a
    pressure valve which shuts off whenever the oil pressure falls below 1.5 Bar. The engine does not feature a
    conventional adaptor plate, instead, the gearbox bolts directly to the engine block. The gearbox casing itself
    houses the starter motor and provides access for the TDC positioning tool, which engages directly into the flywheel.
    The engine has an aluminium structural sump sealed to the cylinder block with a rubber gasket. This gasket features
    integrated metal sleeves (compression limiters) at the points where the sump bolts pass through the gasket. This
    prevents the gasket from distorting as the sump bolts are tightened. The sump gasket should be fitted dry to cleaned
    and dry surfaces. The crankshaft is constructed of iron and incorporates journals with rolled fillet radii to increase
    the crankshaft�s ability to withstand �bending� fatigue. It is not possible to regrind the crankshaft, due to its
    design and the techniques used in its construction. The crankshaft main bearings feature a grooved shell, which locates
    in the cylinder block and with a smooth shell in the cap. The number 3 main bearing includes provision for the two thrust
    washers; these washers are only available in a standard size. It should be noted that all the main bearing caps have a
    slight interference-fit with the cylinder block. This feature negates the need for main bearing locating dowels.
    The pistons feature a graphite coated skirt and incorporate an integral combustion chamber. The pistons have three
    piston ring grooves, housing two compression rings and one oil-control ring. An internal oil gallery, fed by the
    oil squirt jet, cools the piston. The piston design eliminates the need for additional strengthening rings using
    its shape to transfer the combustion forces through to the con-rod.
    The con-rod is identical in design to the con-rod fitted to the Freelander L series engine. It is a fracture split
    con-rod. This means that the big end bearing cap has no machined surface in contact with the con-rod. In manufacture,
    the con-rod is bored to a nominal diameter as a one- piece unit. Two grooves are then machined into the inner land and
    then the cap is forced apart. This causes the metal to fracture, leaving a unique mating surface. Once this process is
    completed, the cap is refitted and tightened using two retaining bolts and the final internal diameter is machined.
    Utilising the fractured state of the cap ensures that the two pieces of the con-rod fit perfectly and possess a strong
    resistance to lateral movement (sideways movement).
    The bolts are located off-centre. This serves to ensure that the cap is fitted to the rod in the correct orientation.
    If, when the con-rod is out of the engine, the cap is fitted incorrectly (the wrong way round) and the bolts are tightened
    then the con-rod must be replaced. This is necessary because the unique profile of the mating surfaces will have been
    damaged when the cap was tightened. The cap will no longer locate correctly, even if it is turned back to the correct
    position.
    The small end of the con-rod is machined to a taper. This allows for clearance between the piston head and the con-rod
    and provides increased load capability by increasing the surface area on both load sides of the gudgeon pin. The small
    end is lubricated by a splash-feed, facilitated by the squirt jets. The big end bearings have no featherway to locate
    them laterally. They rely solely on �bearing nip� to control their position and to eliminate rotational and lateral
    movement. The bearing shell located in the con-rod is different to the bearing shell fitted in the con-rod cap. The
    con-rod bearing goes through a manufacturing process called �sputtering�. This process is used to form very pure
    materials. In this case, the sputtering process is used to increase the con-rod bearing shell resistance to wear and
    is used to offset the greater wearing loads experienced by the top bearing shell. The sputter bearing can be identified
    by having a shiny surface (bearing shell to con-rod side), a dedicated part number and a different appearance when
    viewed from the working side of the bearing as compared to the back of the bearing.
    Flywheel
    The flywheel is a �dual-mass� flywheel. This means it has a proportion of its mass mounted by an internal spring.
    A dual-mass flywheel helps to dampen the unavoidable variations in crankshaft rotational speed which occur at the point
    of combustion for each cylinder. This damping action helps to reduce drive train vibration particularly when the engine
    is at low speed and at idle. The flywheel also incorporates a series of holes drilled into the circumference. These holes
    work in conjunction with the crankshaft sensor to feed back information on the crankshaft speed and the crankshaft phase.
    There are 31 drilled holes, spaced at 10� intervals, around the flywheel. At five 10� intervals the crankshaft has
    not been drilled. This acts in the same manner as having a �missing pole� (i.e. as used on the V8 engine fitted to
    the Range Rover pre-1999 MY). The missing holes are placed unevenly around the circumference of the flywheel. By having
    the crankshaft drilled in a unique sequence, the ECM is able to determine its position in the engine�s cycle within a
    maximum of 130� of crankshaft rotation.
    Cylinder head
    The cylinder head face is heat treated to increase its durability, so it cannot be re-faced. The head houses four glow
    plugs (number 5 cylinder does not have one) and two valves per cylinder. It also features the machining for the camshaft,
    hydraulic lash adjusters, the electronic unit injectors and the low pressure fuel rail.
    The camshaft locates between the head and the cam carrier. These two components are line bored, so form a matched pair.
    It is important to note that the head is subjected to a force equivalent to that of clamping the cylinder head to the
    surface block when it is line bored. This ensures that the camshaft bearing surfaces match the profile of the camshaft
    journals perfectly when the engine is in an operating condition. If the need arises to replace the cylinder head or the
    cam carrier, the other component must also be replaced. The cam carrier is sealed to the cylinder head by liquid sealer,
    in this case Hydrogrip 2000. It is important to apply the correct amount of sealer. Always follow the procedure detailed
    in the workshop manual to ensure that the correct amount of sealer is applied.
    The rocker shaft sits above the camshaft in the cam carrier and has on it five rockers. These rockers are used to generate
    fuel pressure inside the EUI injectors.
    The valves use finger followers to transfer the camshaft lobe movement into vertical valve movement. The finger followers
    locate over the hydraulic lash adjusters and the tops of the valves (see figure below). The finger followers are not held
    rigidly into position, they hold their position by locating on top of the valve and locating over the hydraulic lash
    adjusters pivoting ball. The valve is activated by the lobe of the camshaft pressing down on the roller of the finger
    follower.
    Finger follower and lash adjuster
    When the hydraulic lash adjusters are removed from the engine, they must be stored upright and in clean conditions.
    Failure to follow this procedure can result in serious engine damage when they are reinstalled.
    The cylinder head incorporates the fuel gallery, as previously mentioned. Supply and return connections are located
    at the rear of the cylinder head. All the fuel pipes are connected by means of quick-fit connectors. A fuel cooler
    is mounted on the side of the inlet manifold (see figure below). The fuel cooler cools the hot fuel from the cylinder
    head before it returns to the fuel filter. The fuel cooler has two coolant connections to the radiator. The radiator
    incorporates a small diameter tube dedicated to supplying coolant for the fuel cooler. The small diameter of the tube
    slows the coolant flow, which �super cools� the coolant before it is supplied to the fuel cooler. The fuel cooler
    has a thermostat which opens when the coolant inside the fuel cooler reaches approximately 70�C (160 �F). It is
    important to cool the fuel returning to the fuel filter, as this ensures that the fuel within the fuel circuit is kept
    at a predetermined temperature for optimum performance and emissions.
    Td5, unlike previous engines, is equipped with a fuel cooler on the fuel return lineFuel supply system,the fuel supply system on New Discovery diesel derivative uses an electric two-stage pump. The pump is submerged in
    the fuel tank. Fuel passes through the pump twice before it flows to the engine. In the first stage, the fuel is drawn
    from the swirl pot and flows out of the fuel tank to the fuel filter (line A). The fuel filter is located on the outside
    of the chassis on the right hand side of the vehicle, forward of the rear wheel. This fuel filter is of a canister design
    and should be replaced at scheduled intervals, according to the service maintenance service sheet. Once the fuel has passed through the filter, it returns to the fuel tank (line where it enters the fuel pump for the second time. The fuel pump then boosts the pressure to 4.0 Bar. The boosted fuel pressure is controlled by a pressure relief valve located in the aluminium fuel connector block, which is situated on the rear of the cylinder head. The pressure relief valve controls the fuel pressure by regulating the amount of fuel returning to the fuel filter. The fuel connector block also retains an additional �fit for life� fuel filter. This filter should not be replaced under normal circumstances. However, if a blockage does occur, then the housing can be removed and the filter replaced.
    It is extremely important that no dirt enters the fuel rail as this could lead to engine misfire by blocking an injector
    or making it stick open. It can also lead to combustion gases mixing with the fuel in the fuel rail, causing the engine
    to stop running.
    The fuel is supplied to the engine (line C) and into the gallery within the cylinder head. The injectors then use a
    proportion of the fuel. The return pipe allows the excess fuel from the head (line D) to flow into the fuel cooler.
    Finally, fuel flows to the fuel filter (line E) and back into the fuel pump, ready for the next cycle.
    Care should be taken when disconnecting any part of the fuel system as it can contain hot pressurised fuel. In cases
    where an EUI needs to be removed, follow the procedure detailed in the workshop manual. Failure to disassemble the engine
    correctly, or to not take heed of the warning associated with allowing fuel to drain into the combustion chambers, can
    lead to engine damage.
    Fuel flow diagram
    A. LP out
    B. LP in
    C. HP out
    D. Return pipe
    E. Spill return
    F. Filters
    G. Fuel cooler
    H. HP stage
    J. Water jacket
    K. Air bleed
    L. LP stage
    M. Electonic unit injectors
    N. Water out
    O. Hot fuel in
    P. Cool fuel out
    Q. Cool water in
    Oil pump
    The oil pump, as previously mentioned, is located in the stiffener plate. A chain drives it from the crankshaft. The oil
    pump contains no serviceable parts except for the pressure relief valve spring. The free length measurement of this spring
    is detailed in the workshop manual. It is the free length of the oil pressure spring which determines whether the pump is
    suitable for refitting into the engine. Before the oil pump or crankshaft drive sprocket can be removed, the oil pump drive
    sprocket must first be removed.
    The injectors used by the Td5 engine are located in the cylinder head. A copper washer and an �O� ring are used to seal
    the injector nozzle and injector body to the cylinder head. If, at any time, an injector is removed then this washer and
    the injector �O� ring must be replaced. Extreme care must be taken when removing an injector from the cylinder head as
    the tip of the injector can be damaged if it is handled incorrectly. If the copper washer fails to seal the injector to
    the cylinder head, combustion gases will contaminate the fuel in the fuel gallery. This results in the fuel becoming
    aerated. If this happens, the engine will suffer poor starting and poor performance. Even with relatively small amounts
    of combustion gas in the fuel, the engine performance will suffer noticeably. The injectors �O� ring prevents the
    fuel in the fuel gallery from entering the engine oil supply.
    The EUI injectors are very susceptible to foreign matter in the fuel rail or any dirt or particles around or in injector
    body between the �O� ring and the copper washer. No attempt to clean this part of the injector should be made. Always
    follow the procedure detailed in the workshop manual when removing the EUI injectors.
    The EUI injectors are manufactured by Lucas
    The injectors are electronically operated units in which the fuel injected is pressurised mechanically. Each EUI consists
    of a hydraulic plunger, a conventional injector nozzle and an electric solenoid. The hydraulic plunger is driven
    mechanically
    by the camshaft and rocker assembly. The injector operates in four stages:
    1. The camshaft lobe turns and transfers mechanical force and motion to the rocker, which is in contact with the
    injector hydraulic plunger. This transfer of mechanical force starts to move the plunger down inside the injector.
    At this point, the injector has fuel flowing through it because of the action of the pump located in the fuel tank.
    N.B. Fuel exits the injector via the spill hole back into the fuel rail
    2. As the plunger travels down, it closes the inlet port and prevents more fuel entering the injector. The fuel
    already in the injector can still exit the injector at this stage because the EUI solenoid has not shut off the spill
    port
    3. At a calculated time, the ECM will supply a voltage to the injector solenoid, causing it to activate. This will
    close the injector spill port and cause the pressure within the injector to rise very rapidly. At this point, the injector
    will spray fuel into the combustion chamber at very high pressure (up to 1500 Bar. As a comparison, the current 300 Tdi
    engine injects fuel at approximately 600 Bar)
    4. At the calculated time, the ECM will remove the voltage to the EUI injector solenoid. By doing so, the spill port
    will open and fuel will now flow through the injector, rather than out through the nozzle. The hydraulic plunger will
    return to its rest position by means of a powerful spring. The EUI is now ready for the next injection sequence
    It is critical that each injector delivers the desired quantity of fuel at the required time. To do this, its opening
    and closing times must be controlled precisely. Despite the fact that the injectors are manufactured to extremely close
    tolerances, an amount of variation may exist between them. This is due to slight differences in spring tension and nozzle
    bore dimensions. As a result of this variation, the ECM must be informed of the precise specification of each injector.
    This enables the ECM to adjust its opening and closing injection points to gain the maximum fuel efficiency. This
    procedure is called the calibration process.
    On top of the injector there is a five letter code. This code is used in the EUI calibration process. It details the
    exact performance or �profile� of the injector. Each injector is tested after manufacture and is measured against
    a nominal start of injection point, end of injection point and an idle quality factor. The graph below demonstrates
    how this alpha code is used to tighten the tolerance of the EUI.
    The EUI alpha code can be used to tighten the EUI tolerance in the ECU
    The first two letters of the alpha code refer to the degree of variance from a nominal injector to the measured injectors
    start point. The second two letters in the alpha code refer to the end of the injectors tolerance. The tolerance band for
    the start and end of injection is � 127mS (0.000127 seconds). The last letter in the alpha code is a measured variance
    in idle performance. The injector is given one of three idle letters: A, B or C.
    The alpha codes used for both the start point and the end point are not sequential, i.e. not AA through to ZZ. The codes
    have been picked at random to stop the possibility of deliberately over-fuelling the engine in the search for greater
    performance.
    The letters do not denote that one injector is better than another injector. The letters give the ECM the mapping
    adjustment needed for that particular injector, to enable very precise fuelling and smooth idle performance.
    It is important that the injector code is programmed into the ECM if an injector is replaced, or if the order of the
    injectors is mixed up. This procedure is completed with the aid of TestBook. The injectors are operated electrically
    by the ECM, which is able to produce a voltage of approximately 80 volts at 8 amps to shut the injector spill port.
    This is a considerable amount of electrical energy. Appropriate care should be taken while working with a running engine.
    The rockers which transfer the downward force on the EUI must be adjusted correctly at all times. The process used to
    set the adjustment is dissimilar to conventional tappet adjustment procedures. The procedure is as follows:
    1. Loosen the lock nuts on all the adjusting screws (this should have been completed before the rocker shaft was
    removed)
    2. Set the engine to a position where the EUI to be adjusted is fully compressed, i.e. the cam lobe is at its highest
    point. There is a timing mark on the front of the camshaft for each of the injector�s lobes. This mark will align with
    the edge of the cam carrier housing to signify that the relevant injector lobe is at its maximum point
    3. Screw the adjuster �in� to further compress the EUI hydraulic plunger spring (this will feel quite stiff).
    Stop when the plunger contacts the base of the injector (at this point it will not be possible to screw the adjuster
    in further)
    4. Turn the adjusting screw back 1 turn and tighten the lock nut
    5. Repeat steps 2 - 4 for the other four injectors
    This adjustment procedure should be carried out whenever the rocker shaft has been removed. When adjusted correctly,
    the injector plunger travels the correct distance. If not adjusted correctly the plunger could either travel too far
    and make contact with the base of the chamber or may not travel far enough. In both cases, damage and a reduction in
    engine performance could result.
    Timing chain
    The timing chain is a duplex link chain driven by the crankshaft. It has 56 links, three of which are of a bronze colour.
    The significance of these links will be described when the engine timing procedure is explained. The timing chain runs
    over two plastic guides. One of the guides is fixed rigidly to the cylinder block, whilst the other is kept tight against
    the chain by a spring-tensioned and oil damped chain tensioner. The timing chain tensioner locates through the side of the
    head. The tensioner has a direct oil feed, which provides additional tension to the chain as well as dampening transient
    vibrations in the timing chain when the engine load changes.
    To fit the timing chain correctly the crankshaft and the camshaft must be in set positions. The crankshaft should be
    locked at TDC using the correct special tool. The camshaft can then be located by inserting special tool LRT 12 058
    through the cam carrier into a locating slot machined into the camshaft flange (see figure below).
    The timing chain has three bronze-coloured links for alignment purposes
    The bolts securing the camshaft sprocket should remain loose at this stage to allow the sprocket to move independently
    of the camshaft. The bronze coloured links in the timing chain are used to position the chain correctly on both sprockets.
    The two adjoining bronze links should be placed either side of the machined mark on the camshaft sprocket. The single
    bronze link should be placed in-line with the machined mark on the crankshaft sprocket. At this point, both chain guides
    should be fitted and the chain adjuster inserted to tension the timing chain. The camshaft sprocket bolts should then
    be tightened to the specified torque. Both special tools should be removed and the crankshaft rotated twice. The crankshaft
    timing pin should then be reinserted. It should now be possible to insert the camshaft tool LRT 12 058 without resistance.
    If not, the procedure should be repeated.
    The timing chain
    Oil filter
    The Td5 engine features two oil filters. The primary oil filter is a conventional canister type. The primary oil filter
    filters all the oil entering the oil gallery and the oil entering the secondary oil filter. The primary filter features
    a paper element which is used to trap particles as small as 15 microns (0.015 mm) in diameter. But diesel engine produces
    many particulate impurities smaller than this and these particles are removed efficiently by the secondary centrifugal
    filter. Therefore, the service life of the primary oil filter canister can be greatly extended. Always refer to the
    maintenance check sheet for the correct service interval for both the primary and secondary oil filters.
    The secondary oil filter is a centrifugal oil filter which is housed in a �pot� located by the exhaust manifold.
    The pot lid is sealed to the pot by an �O� ring. This �O� ring should be replaced when the centre canister is
    replaced. The oil filter works by the replaceable centre unit spinning very rapidly. The unit has two very fine holes
    drilled at an obtuse angle so that when oil flows through them under pressure it spins the centre filter unit. The
    centre of the centrifugal filter can rotate at speeds up to 15,000 rev/min. The inner surface of the spinning canister
    gets coated in a gel of old engine oil and carbon particles. The centrifugal filter is capable of retaining much finer
    carbon particles than a traditional canister type oil filter.
    The oil pressure warning switch is located in the housing under the turbocharger. The oil pressure switch will go to an
    open circuit state (light off) when the oil pressure rises above 0.5 - 0.68 Bar.
    The centrifugal oil filter is capable of capturing miniscule carbon particles
    The housing between the two oil filters and the cylinder block incorporates an oil cooler (see figure below). The
    oil is passed through the oil cooler via a thermostat in the oil filter housing, which has a 72 �C (160�F)
    opening temperature. The oil is then cooled by the cylinder block water jacket.
    The oil passes through an oil cooler after the primary filter
    Turbocharger
    The turbocharger used on the Td5 engine is a Garrett GT20. This unit features an electronic modulating wastegate.
    This enables the ECM to control accurately the amount of boost pressure the engine receives. The conventional care
    points should be observed when starting and stopping the Td5, i.e. allow the engine to idle for 15 seconds immediately
    following start-up and before the engine is switched off.
    Cooling system
    The cooling system uses a 50/50 antifreeze/water mix. The specified antifreeze to be used in this application is
    Texaco XLC. The capacity of the system is approximately 10 litres. The workshop manual details the procedure to
    drain and refill the cooling system.
    The cooling system hoses have been fabricated to incorporate a thermostat housing. This thermostat housing has
    three hose connections. The coolant is drawn into the water pump via hose (F) from either the heater matrix
    circuit (D) or from the thermostat housing (A). When the thermostat ( is closed, the water pump will draw fluid
    from the bypass hose (E). Before it is able to do this, it will need to overcome a spring-loaded valve (C) inside
    the thermostat housing (A). This spring is rated so that, when the engine speed is below approximately 1500 rev/min,
    all the coolant will circulate around the heater circuit (D). This serves to aid fast �warm-up� when the vehicle
    is operated in cold climate conditions. If the engine speed exceeds approximately 1500 rev/min, the suction the water
    pump creates will be sufficently strong to lift the spring-loaded valve (C) off its seat. This will allow coolant to
    circulate through the bypass hose (E), as well as through the heater circuit (D). When the coolant temperature exceeds
    82�C (180�F), the thermostat ( will open, allowing the coolant to flow through the top hose (E), through the
    radiator and into the thermostat housing, via hose (G). Finally, it will be drawn into the water pump via hose (F).
    A cooling system flow diagram
    The auxiliary drive belt is used to drive the following items (depending upon the vehicle specification):
    1. The viscous fan
    2. The water pump
    3. The alternator
    4. The vacuum pump (via the same pulley as the alternator)
    5. The power steering pump
    6. The air conditioning compressor
    7. The active cornering enhancement control pump
    The auxiliary drive belt is tensioned with an auto-tensioner. The auto-tensioner has an uprated spring
    to provide the belt with greater tension than the 300 TDI. This is needed because of the extra power transfer
    required to drive the above components.
    The Td5 engine features an integrated 120 amp alternator and vacuum pump. It is driven directly by the auxiliary
    belt and supplies vacuum for the servo assisted brakes, and for the EGR modulating valve.
    There are four auxiliary drive belts, each of differing length. The drive belt fitted is determined by the
    specific components fitted to the vehicle. Each drive belt is colour coded to assist with identification.
    The table below identifies which belt is used for each vehicle derivative and provides a key to the colour
    coding.
    Colour Length mm ACE A/C Configuration Figure No.
    White 1716 No No No ACE or A/C 1
    Yellow 1820 Yes No ACE only 2
    Green 1801 No Yes A/C only 3
    Red 1867 Yes Yes ACE and A/C 4
    Figure 1Figure2
    Figure3Figure4
    The Td5 engine features an innovative solution in the control of crankcase emissions. The new
    system ensure that very low levels of oil mist enters the combustion process or escapes to the
    atmosphere. The new rocker cover has cast into it five circular, sequentially positioned chambers
    (see figure below). These chambers force the oil mist into a cyclononic movement from one chamber
    to the next. As the mist races around each chamber, any oil particles are flung to the chamber
    walls where it then collects and falls back into the cylinder head via the two air inlet holes
    located at each end of the rocker cover.
    May 2003
    On The Road
    did the site have a graph for the V8?
    NSW , Pennant Hills
    Is this what you're after?
    and here is one for 3.5
    sanduu Guest
    Hello all,
    For some reasons, the pictures that were in the TD5 description are pointing to Discovery Owners Club :: Welcome to the Land Rover Discovery Owners Club. If any of you have acces to that site, can you then please re-post the thread with pictures?
    Thanks in advance,
    Regards,
    Sandu
