Results 1 to 10 of 33
Thread: air filters td5
    Brisbane,some of the time.
    air filters td5
    hi,has anyone noticed dust downstream of the air filter?am on my 3rd td5 & they all did this.have used genuine & coopers filters & same problem.all my td5s were bought new & the dealer ignored the problem.a few years back spoke to the lr dealer in alice springs & they had notice this problem but said they did not believe the problem was major .my commodore is perfectly clean downstream of the airfilter. after a recent trip to the cape iwas thinking about the problem &thought the dirt may be getting around the rubber seal on the air cleaner. i have now put grease around theseal & will see how it goes.cannot use an oiled air filter as have heard of oil getting on sensors & airfloww meters & causing problems. HAS ANYONE ELSE NOTICED THIS? look at the plastic grid across the front of the airflow meter & you will see what i mean.regards paul
    Had mine out the other week, spotless, no dust past the air filter and have never noticed this as a problem in 5 years.
    not in big red.
    nothing oil or dust wise where it shouldnt be.
    99.87 MB
    Yep, mine has done this. It really ****es me off knowing that dust has gone through the engine. The filter feels firm when it goes in, but doesn't always hold the seal for some reason. The lid of the airbox also has a lip on it which can snag if you're not careful, but they leak despite checking this.
    Slunnie
    Yep, same here.
    To me the concept is wrong. The filter should be into the lid and not the bucket.
    The way it is now there is too much risk of the lid not being secured properly and allowing air to slip pass the seal and therefore into your engine unfiltered.
    Maybe another rubber seal should be put into the bucket to fill the gap.
    Gold Coast, Qld
    Quote Originally Posted by Feral View Post
    That's excatly what I did and it seems to have worked.......need to change the seal agian soon though as it's squashed down a fair bit over time.
    '99 Manual TD5 D2.......heap of money spent on it and it has ended
    ACT
    yep, quite a bit of dust getting past my Td5 filter. Initially used some white teflon grease to get a better seal, but this is messy and I was worried about any effect on sensors. Have now inserted a twin-lipped rubber seal (used to stop drafts around doors) into airbox top which works fine.
    Always looking for creative new ways to get bogged... :whistling:
    76 RR...sold coz fuel was expensive at 70c/l :eek:
    93 200 Tdi Disco...old faithful...sold to make way for...
    99 Td5 Disco ACE...nice drive...hopefully reliable...
    Williams West Aust
    I have found the same and brought it up a while ago.JustinC suggested it was common,his tip was to use rubber grease on the seal,fixes the problem.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Bunbury, WA
    TD5 Dust Injestion
    I have had heaps of problems with dust getting past the air filter on our D2 TD5 ever since new. It would only take say 10kms of reasonably dusty road for the air filter to become totally clogged and let dust through into the engine. I checked all of the seals in the air box which all worked fine.
    I finally tracked the problem down to where the air was drawn from. The air box draws air from the gap between the inner and outer guard. The problem was that the front of void between the inner and outer guard (near the headlight) is mostly blocked by a plastic baffle. This meant that the air was drawn from the rear of the void right at the bottom rear of the guard. This is a perfect position to collect ALL dust that was thrown up by the front wheel. I made an air pipe (from 90mm stormwater pipe) that connected to the inlet as it came through the inner guard and directly drew air from behind the headlight. I have had no problems with dust in the filter since.
    Now our D2 in standard except for a TJM bullbar, which did require removal of the front bumper. I am baffled though how our D2 picked up so much dust, but I have not heard of this issue with others????
    i have seen the baffle & believe it is to stop water getting into the air intake during water crossings.mine doesnt seem to pick up an excessive amount of dust.i replaced two air filters on a 7500 km dusty cape trip,one halfway through the trip & one at the end.
    what i cant understand is if this problem is pretty common, why arent there more engines getting damaged?
    anyway havent checked mine since i put the grease around it as havent done enough dusty ks
