Point this out to the dealer as a design problem. You might get lucky & have them replaced under warranty.
Then, remove them before you go off road as it's a common problem when they scrape.
 Fossicker
						Fossicker
						These are mine after a weekend on the sand dunes at Robe. They are a poor design with no support for the large inner area of rubber. Has anyone fitted something better and that looks good or should I just get them replaced at the next service
As Scouse advises, I have removed mine (permanently?).
Best Wishes,
 ChatterBox
						ChatterBox
						This is how I solved mine:
DISCO3.CO.UK - View topic - Modified Sand Ploughs (flaps)
 TopicToaster
						TopicToaster
						I have a semi broken one now, waiting for it to fall off before doing a fix.
Check this out; [url=http://www.disco3.co.uk/forum/post212768.html#212768]DISCO3.CO.UK - View topic - Replacing mudflaps
I had one damaged on the Simpson Desert trip, managed to make a repair that is not too noticeable, but I will make some replacements for up and coming trips.
After 3 broken sets, mine are now the same as CarverD3's. Same idea after breaking the last set in the Simpson.
Need someone to design a flexible set.
 ChatterBox
						ChatterBox
						You can either stick a bit of rubber imediately behind the wheel, which will not be stiff enough to keep the stoes away from your trailer.
Or if do what I did, using the LR originals as a base, they are in the right possition and the LR originals keep the rubber well positioned so it doesn't flap.
Some work involved though.
here's my repair job
 ChatterBox
						ChatterBox
						Unfornunately repairs are only temporary. I plastic welded mine together three times before I decided to modify. Only one small crack siince which just need welding, thats all.
