Results 1 to 8 of 8
Thread: Project Iceberg
    Kippa Ring
    Project Iceberg
    Was looking through some Rangie stuff on the internet and saw a couple of references to "Project Iceberg". Apparently in the early 80s they were looking at making a diesel version of the 3.5l v8 but canned the idea and used the VM motor instead.
    Does anyone have any info on this and why they didnt go ahead with it.
    Series 2 LWB - Gone
    Series 3 LWB - Gone
    Series 1 LWB - Gone
    81 RR 2 door - Gone
    95 Disco v8 - The Next Victim
    Kyabram, VIC 3620
    It was put on Iceberg
    Somewhere else, QLD
    The longer version is, beancounters got in the way. The bolt on stuff, steel crank and other stuff was a bit too pricey for the estimated volume of sales. Remember that it was the 80's and 20L/100k was easy to handle.
    Christchurch NZ
    Quote Originally Posted by jbarracl View Post
    I believe blowing head gaskets was a large part of the reason not to go ahead with it, not enough head bolts holding the heads down. Sounds an awful lot like the 350 v8 oldsmobile and v8 Chev Diesels.
    1995 Defender 110 300TDI :D
    1954 86" Series 1 Automatic :eek:
    Ex '66 109" flat deck, '82 109" 3 door, '89 110 CSW V8, '74 Range Rover, '66 88" soft top, '78 88" soft top, '95 Disco ES V8, '88 Surf, '90 Surf, '84 V8 Surf, '91 Vitara.
    See the Wikipedia Rangerover entry :-
    "From 1979 onwards, Land Rover collaborated with Perkins on Project Iceberg, an effort to develop a diesel version of the Range Rover's 3.5-litre V8 engine.[11] Both naturally-aspirated and turbocharged versions were built, but the all-alloy engine blocks failed under the much greater pressures involved in diesel operation. The project was, therefore, abandoned. The effort to strengthen the Rover V8 for diesel operation was not, however, completely wasted; the 4.2-litre petrol variant of the engine used crankshaft castings developed in the Iceberg project"
    Although that is probably what you found. It is about the extent of my knowledge of it, although I think there was an article about it in LRO several years ago.
    Avoca Beach
    As I understand it, JE Engineering bought all the excess crankshafts and then made a JE 4.2, by offsetting the throws as the journals were bigger than a normal 3.5/3.9.
    Land Rover then paid JE to use the design for the 4.2 introduced with the long Wheelbase. I am not sure but Land Rover may have even bought back the cranks. Irony.
    Regards Philip A
    Kippa Ring
    Would have been an interesting motor, ahead of the competition, like most rangie stuff was.
    Series 2 LWB - Gone
    Series 3 LWB - Gone
    Series 1 LWB - Gone
    81 RR 2 door - Gone
    Jun 2003
    Launceston, Tasmania
    I have seen the odd photo of the engines on display at land rover or at a car shwo as well.
    1994 Discovery TDi
    2004 Discovery 2 TD5
    2010 Discovery 4 TDV6
